Slow Upload Speed, Gradually Dropping Over Time
Parallax
I used to get upload speeds of around 18Mbps, which is the estimated speed that appears in my dashboard. Over the last few months, this has been gradually slowing down. It's now 14.79Mbps, which feels too slow for what I use it for. Any ideas?
3 REPLIES 3
MatthewWheeler
Fixes: 463
Re: Slow Upload Speed, Gradually Dropping Over Time
Hi @Parallax
I'm really sorry for how long it's taken to get back to you. We've been quite busy recently so it's taking longer than we'd like to reply.
My tests are showing that your upload sync speed is still 20Mbps which is within expectations.
Are you testing the speed over a wired or wireless connection?
 Matthew Wheeler
Parallax
Thanks for checking the line. I've carried out the same tests using a desktop PC connected to my router via ethernet and on the router itself using its built-in speed checker, with both methods yielding the same results. My hardware and network settings have remained the same for well over a year, so I'm assuming neither of those are responsible for the gradual reduction in speed.
willcutforth
Fixes: 78
Are you using the hub 2 router @Parallax or a 3rd party one? Just so we know the way it's set up.
 Will Cutforth
