Slow Unlimited Fibre
AnnClapton
Why is my Unlimited Fibre so SLOW? 9mb Up 33mb Down.
This is not proper fibre speed? Should be more 20mb Up and 60+mb Down
My account says:-
An error has occurred
You can't change your products for the moment, you already have a product change in progress.
I have not made any changes?
Any ideas or shall I change provider?
10 REPLIES 10
Legend
Fixes: 258
Re: Slow Unlimited Fibre
@AnnClapton Ignore the 'Account Change' message for now - we can sort that later.
We need to sort your speed issue first, so:
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
AnnClapton
The phone makes an odd 2 tone sound when picked up and lots of crackling on the line.
Why is everything so hard to get fixed.
Troubleshoot by txt??? 8am-7.30pm Huh
AnnClapton
@willcutforth Can you assist please? My speed was much better when I was with talktalk?
Found the 2 tone was 1571 which I didn't know I had BTW
Legend
Fixes: 258
@AnnClapton
If you make a text report after 19.30, it will be picked up after 0800 the next day, although I have heard that the automatic system can sometimes place a repair order outside these times.
FYI, although staff do patrol these forums, it is not on a regular basis, which is why the Community try to help. The forums are not an official support channel.
pjmarsh
Fixes: 21
Are you on Unlimited or Unlimited Extra?  Your download speed is slightly low for a decent line on Unlimited Fibre. You'd need Unlimited Extra to get 60mb down and anywhere near 20mb up.
Legend
Fixes: 258
@pjmarsh Reading the original post, I suspect the OP is on UFE, with a problem, but I could be wrong.
pjmarsh
Fixes: 21
Possibly, but thought it worth checking.  As they are comparing speeds to TalkTalk they could be quite new, and those speeds could be Unlimited Fibre depending on how they are being measured and how accurately they are, and since they specifically mentioned Unlimited Fibre (though easy to not know to significance of the difference for someone new around here), I think it's worth making sure that the package they have gives them what they are expecting.  It should be a quick and easy one to rule in or out.
Legend
Fixes: 258
Fair enough, @pjmarsh , but I'm going to make a bold statement here - I bet the OP never comes back.
AnnClapton
Ran text tests, must be a line fault as engineer booked for 22nd Aug 2023
Legend
Fixes: 258
@AnnClapton My apologies - you did come back. 😀
That was my suspicion all along, which i why  suggested those tests.
