Slow Throughput - PN profile Maybe?
- Slow Throughput - PN profile Maybe?
- « Previous
- Next »
Re: Slow Throughput - PN profile Maybe?
14-05-2012 5:04 PM
14-05-2012 5:50 PM
@grudkin - I too have read the mixed results of the DG834Gv2, but I'd imagined that the performance would be evidenced by poor sync rates. Anyway, the Draytek 2710 ought to tell the story.
Cheers,
G
14-05-2012 7:43 PM
Quote from: gimmon ..................... but I'd imagined that the performance would be evidenced by poor sync rates. Anyway, the Draytek 2710 ought to tell the story.
Mmm, I have seen modem/routers that are getting knackered or gone faulty because of poor design, still syncing ok but giving rubbish throughput results. But as you say, hopefully the Draytek will tell the story.
14-05-2012 8:15 PM
Quote from: _Adam_Walker_ FYI there are options to buy up front or free on a deferred contract as mentioned by grudkin, however we don't loan routers I'm afraid.
Adam
I'm interested in buying one upfront as my present router is getting a bit old in the tooth.
You have my details for a one-off payment. What is the best way to set about this?
TIA
14-05-2012 9:42 PM
14-05-2012 11:06 PM
Quote from: Heloman I'm interested in buying one upfront as my present router is getting a bit old in the tooth.
Why? If you take the router and then decide to leave within the year you'll pay exactly the same as if you pay up front (but you've delayed having to pay for it). If you stay with Plusnet for the year you get it for free.
15-05-2012 7:47 PM
That never occurred to me
If I don't stay for a year it would be my executor who has to pay the £40.....
Duh!
15-05-2012 8:48 PM
So, using the DrayTek 2710n over a wired connection, I am seeing a slight improvement:
Download speed achieved during the test was - 12.59 Mbps
For your connection, the acceptable range of speeds is 0 Mbps-0 Mbps .
Additional Information:
Assured Rate IP profile on your line is - 0 Mbps
However, earlier today, Plusnet support increased the noise margin on my line. The result of that was to drop my sync rate to 18200 kb/s using the original router. But using the DrayTek, I am still syncing at 19500 kb/s.
Grateful for the small improvement, but I still think it could do better - still a way from the profile rate. I am not sure that the noise margin change has helped (results still the same results with the Netgear) I would guess that the performance of the DrayTek is the bigger factor. Actually wishing the noise margin hadn't been changed until after the DrayTek test.
Cheers,
G
15-05-2012 9:04 PM
It would be unusual for Plusnet to increase the Noise Margin, I suspect that you just saw a higher SNRM because the noise on the line reduced a bit, I don't think you would have synced higher with the Draytek if the Target SNRM had gone up. In any event it would have been the exchange DLM to have done that.
Can you post the full stats from the Draytek as well?
15-05-2012 9:16 PM
OK, I might have mis-phrased. Here's a quote from the Plusnet ticket:
"I appreciate this is getting frustrating so I have made a change on the line to try to increase the throughput, this change includes resetting the line to raise the noise margin on the line. This will ultimately add further stability but will decrease to top synchronisation speed slightly however not to a level where you can physically notice the difference. This change takes between 4-24 hours to take effect on the line."
The Netgear definitely syncs about 1000 kb/s slower than before (and the noise margin has increased from 3db to 6db), but you can see the Draytek stats attached.
The Speedtester results are from the 'Additional Tests' page not the main one (I forgot to capture but they reported an IP Profile of 17.59 Mb/s and a throughput of 12.5 Mb/s). Will run again in an 30 minutes.
Cheers,
G
15-05-2012 10:10 PM
15-05-2012 11:13 PM
As for the throughput, this could be congestion somewhere. I was typing this reply as my connection dropped and now seeing the latest BT speedtest that is definitely my opinion with the upload speed being down as well. Check which Gateway you are on, then do a Gateway hop (click on Drop PPoA on the Draytek interface I'd guess, and then Connect or whatever it says if it doesn't do it automatically) and run another speed test. Check which new Gateway you are on.
18-05-2012 8:09 AM
I have good news, BT Speedtester reporting 14.37 Mb/s Download speed with an IP Profile of 18.23 Mb/s (79% of profile rate). Much more like it, I'd say.
Unfortunately, I can't definitively say what the issue was. Rather looks like it's down to the Draytek 2710n being much better than either of the Netgear DG834Gv2s I tested with. Plusnet support increased my target noise margin, but the Draytek still syncs at 20.18 Mb/s, but I wish I'd tried the Draytek before they did that so I had a fair comparison. In fact, I've asked them to reverse the change as I think it's a red herring. My line was very stable so I don't see how the noise margin would help with throughput. Please educate me if I'm wrong. Incidentally, the Netgear still performs as poorly as before.
Support did report that copper line tests at the exchange were 'problematic' not sure if that was also a factor.
Plusnet don't seem to want to reset the noise margin, which I am disappointed about.
Cheers all.
18-05-2012 9:37 AM
22-05-2012 10:51 PM
Plusnet agreed to un-set the target noise margin resulting in sync rate of 21.74Mb/s. Speedtester indicates an IP Profile of 19.64Mb/s and a throughput of 14.31Mb/s, a result of 73% of profile rate during the evening seems reasonable. Achieved using a DrayTek 2710n using a Ethernet cable.
Conclusion: poor ADSL2+ performance with both of my Netgear DG834Gv2 routers.
Many thanks to all for your suggestions.
- « Previous
- Next »
