Slow Throughput - PN profile Maybe?
- Slow Throughput - PN profile Maybe?
Re: Slow Throughput - PN profile Maybe?
10-05-2012 3:46 PM
My set-up is as basic as I can imagine:
Windows XP SP2 Laptop with Core 2 Duo P8800 and 2GB RAM and wireless turned off.
Browsers: MS Internet Explorer 8 and Chrome 19.0 with Java 1.6 JRE
Connected directly (1.2m CAT5 cable) to a Netgear DG834G v2 (firmware V3.01.31) router with wireless access point turned off and otherwise standard config.
Router connected via a 2m RJ11 and Fujitsu microfilter to the BT master socket (face-plate off into test socket). No other devices connected to phone line - net even telephone.
I have varied the router (with an identical DG834), changed microfilter and used a different Ethernet cable (both high quality i.e. not home-crimped).
Speed test sites used:
speedtester.bt.com
speedtest,net
www.bbc.co.uk/iplayer/diagnostics
I've just run another BT test (15:39 10/05/2012):
Download speed achieved during the test was - 8.94 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 17.39 Mbps
Honestly can't think what more I could do to optimise, but would value any suggestions.
Cheers,
Adam
10-05-2012 3:55 PM
10-05-2012 5:35 PM
Running on wireless (11g) BT Speedtest at 17:26 10/05/2012:
Download speed achieved during the test was - 6.2 Mbps
Creeping into the evening peak I guess, but clearly not faster than via cable connection.
I don't have another ADSL connection test it with, but my laptop is frequently connected via a corporate LAN and I've seen 26Mb/s achieved on speedtest.net.
I have another PC in the house, so I'll run the BT Speedtest from that once the one hour has elapsed and post the results. Have tested from that PC before, but worthwhile checking as I appreciate we need to eliminate all possibilities.
Cheers,
G
10-05-2012 5:59 PM
10-05-2012 7:27 PM
Download speed achieved during the test was - 9.97 Mbps
Cheers,
G
10-05-2012 8:46 PM
Download speed achieved during the test was - 9.82 Mbps
Cheers,
G
10-05-2012 10:03 PM
now my upstream is slow (although I guess it's a one-off)...
Download speedachieved during the test was - 9.54 Mbps
Upload speed achieved during the test was - 0.07Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
11-05-2012 4:54 PM
11-05-2012 5:08 PM
I have tried another router (an identical DG834G v2). I guess I could try and borrow a different model.
What I'm struggling to accept is the fact that every piece of evidence on line and connection properties points to a high performing service. It just behaves as though it's being throttled, hence my original question about PN IP profile.
Need to find someone else who's connected to THHW exchange and has with similar line properties!
Cheers,
G
12-05-2012 1:36 AM
Can you copy and paste the full results from the BT speedtest?
12-05-2012 8:47 AM
No, never had BT VIsion.
Full results attached (just run again at 0835 12/05/2012) - including the additional tests page, which does indicate that the 'other service' is related to Vision. You can see from a response earlier in this thread that this oughtn't affect broadband, though.
In case you're wondering, if I initiate the additional test , I just get a timeout error.
Thanks for your interest,
G
12-05-2012 10:28 AM
Quote from: Anotherone I see your exchange VP status is supposedly Green, but I'm baffled by this "other service" on your line purported to be something to do with BT Vison! Have you ever had BT vision?
Seems like the BT speed tester has been changed (possibly for 21CN users only), as I too now have the assured rate test, my results below.
14-05-2012 12:00 PM
It may be possible that your router isn't ADSL2+ compatible. I've just had a look at the specs on the Netgear website and it doesn't mention ADSL2+ Can you get your hands on a router that is and see if it makes the difference?
Jojo
14-05-2012 12:39 PM
Well, I am at firmware version 3.01.31 so please see below:
http://support.netgear.com/app/answers/detail/a_id/258/related/1
However, I accept the point that given the router is getting on a bit, it would be nice to try with a different model. Do I want to shell out £60 for a new router? If it solved the problem, I would do. I wonder if Plusnet have a loan router?
Cheers,
G
14-05-2012 4:09 PM
This means that you would only have to pay the £40 for the TG582n if you leave Plusnet within the 12 month contract!
I have now been using a Plusnet provided TG582n router for over 2 weeks and I am really pleased with it!
After a search there seems to be very mixed results of success with the DG834Gv2 on firmware version 3.01.31 using ADSL2+
