Slow TBB speedtest
Fixes: 10
Slow TBB speedtest
Thinkbroadband speed tests are odd tonight - I'd normally expect to see around 6.7mbps
Speedtest.net and BT's test are near normal. IP Profile is nailed on 7.15 as normal, portal current line speed is the same. Tests conducted wired.
Router stats are excellent as normal:
Uptime: 23 days, 0:53:33
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 832 / 8,128
Data Transferred (Sent/Received) [GB/GB]: 3.11 / 12.70
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 11.0 / 20.0
SN Margin (Up/Down) [dB]: 13.0 / 6.5
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 36 / -
Loss of Signal (Local/Remote): 4 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 256 / -
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 246 / 263
HEC Errors (Up/Down): - / 231
This is a normal test for me:
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Re: Slow TBB speedtest
Normal here on  ptw-bng01
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Fixes: 10
You've just reminded me: ptw-ag01
Just tried again:
and after a hop to pcl-ag02 better speed but still very variable:
Fixes: 21
ptn-ag02
All pretty normal here, although I've never been sure why the x6 results are always rubbish.
Fixes: 22
Jelv,
What is your BQM like?  Any sign of congestion there?
Kevin
Fixes: 10
I've been asked to change to my normal login instead of the IPv6 login and for some reason in doing so the router has reverted to not responding to WAN pings. I've just got home after two days in London (daughter at St James's Palace for DoE Gold presentation), found the red BQM and sorted it out so I can't tell. We'll have to see what it is like next Monday.
