Slow Sync speed...
- Slow Sync speed...
Slow Sync speed...
16-03-2011 9:41 AM
I've just transferred from Sky BB to Plusnet (7 days ago).... 8 days ago on my Sky Router was syncing at 4megs download.... 7 days ago my Plusnet Thomson Router TG585 v7 connected happily (!) at 200K and hasn't budged since....
I sent PlusNet an email asking if this was 'expected' behaviour in first 10 days... They said 'yes' but I'm not so convinced.... Certainly in previous switches I've not experienced such a persistent slow connection for 7 days... My previous low sync speeds were due to a line fault and were resolved.
I've tried switching to another router borrowed from friend and that syncs at the same slow speed.
I admit I'm only on the 7th day of testing but I can't help worrying that a change of zero in the last 7 days on daily reboots and two different routers suggests something is wrong... I can also assume that as the slow sync arrived at the change of provider that my link with the local exchange is probably OK so this is not a hardware fault.
So what can cause this problem? And is it really true that in the next 3 days I'm likely to get my 4 meg connection miraculously return having stayed a static 200 K for the last 7?
Looking forwards to the answer...
Andy
Re: Slow Sync speed...
16-03-2011 10:17 AM
Were you on Sky LLU?
the training period on a change over is ten days and normally PN cant do anything until that is complete
have you looked at your router stats, that will give you a clue what you line will support see her how to get them http://www.kitz.co.uk/adsl/frogstats.php
16-03-2011 10:30 AM
I'm not sure if I was LLU with Sky... Although I suspect I might be as trying to move my phone to another provider (Planet talk) is proving tricky as they don't think I have a BT Line..
My Stats:
Link Information
Uptime: 0 days, 14:41:36
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 440 / 281
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 1.00
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 26.5 / 45.0
SN Margin (Up/Down) [dB]: 25.5 / 13.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): 4,294,967,264 / 772,460
CRC Errors (Up/Down): 4,294,967,264 / 33
HEC Errors (Up/Down): 0 / 7
16-03-2011 3:09 PM
16-03-2011 5:35 PM
I hadn't realised until today how to do that.
Andy
16-03-2011 10:43 PM
Software Release: 8.2.6.5
For some reason it wouldn't connect using the 'auto configure' I had to log in and put my adsl username etc on.
For all the difference it made.... I'm now on a new phone wire from Router to BT box just in case I'd broken the old one when swapping routers...
Details now:
DSL Connection
Link Information
Uptime: 0 days, 0:09:21
Output Power (Up/Down) [dBm]: 13.0 / 0.0
SN Margin (Up/Down) [dB]: 25.5 / 5.5
FEC Errors (Up/Down): NA / 41,622
CRC Errors (Up/Down): NA / 0
HEC Errors (Up/Down): 0 / 0
I guess this will have to wait for Plusnet support to kick in after 10 days....
16-03-2011 11:54 PM
SN Margin was 13dB in your post this morning. That's a huge drop between daytime and night-time environments. Does you phone line run close to street lights or any security lighting (or does noise margin change when the CH goes off)?
17-03-2011 12:13 PM
Noise levels always used to increase in the evening, although last night that reading was taken after CH was off. The line comes into the house on an overhead cable which was replaced about 4.5 years ago as it had warn through! It then goes straight into hardwired (integral) filter and straight into router. There is only one phone also attached to this.... I disconnected the rest of the house extensions in an effort to reduce noise levels 4.5 years ago!
Will Openreach have records of my speeds over the last few months even though I've moved providers? I'm concerned that my new speed will be considered to be what I've always had!
Regards
Andy
17-03-2011 1:10 PM
17-03-2011 2:35 PM
(Oh, and is Plusnet now sending out v7 routers again? I thought they were all v8 these days.)
Graham
17-03-2011 3:24 PM
In interests of environment and saving postage I decided not to claim a new router..... If I thought this would resolve the problems I'd claim it!!
17-03-2011 4:12 PM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13003781748659.png" />
All I can recommend really is the usual intermittent connection checks (plug router into master socket with all non ADSL items removed - if you can get to the test socket (behind the master socket front plate) then that would be even better) - if the sync speed or noise margins haven't improved then it's definitely a line fault and needs reporting at http:// faults.plus.net
22-03-2011 1:43 PM
I'm still struggling to technically understand how a drop in sync speed coincided with switch from Sky.... does anyone have any idea?
