Slow Speeds.
- Slow Speeds.
Re: Slow Speeds.
02-01-2008 5:16 PM
Would you mind trying to reboot your router? It may need a reboot to pick up the newer, higher profile.
Re: Slow Speeds.
02-01-2008 5:51 PM
Would more reboots help?
Re: Slow Speeds.
02-01-2008 5:53 PM
Can you keep an eye on things over the course of the eveninig to see if things improve towards "quiet" times? It could potentially be an exchange contention issue.
Re: Slow Speeds.
02-01-2008 6:08 PM
The results of our tests show no fault with your broadband connection. Completed speed tests show that your connection speed is: none found
According to BT, this speed is within the limits of acceptable performance for broadband service.
"none found" surely this can't be right?
Re: Slow Speeds.
02-01-2008 6:14 PM
Re: Slow Speeds.
03-01-2008 9:50 AM
Still no consistencey.
Re: Slow Speeds.
03-01-2008 10:20 AM
I wonder whether it might be an MTU/rWin issue.
Can you have a look here:
http://www.plus.net/support/broadband/troubleshooting/rwin_guide.shtml
If you try downloading DR TCP from here:
http://www.dslreports.com/drtcp
And setting MTU to 1430 on your computer and router (if your router allows you to) and settings the Receive Window to 83400.
You'll need to reboot after applying these changes and it *may* help your connection speeds.
Re: Slow Speeds.
03-01-2008 1:38 PM
Re: Slow Speeds.
03-01-2008 1:39 PM
Re: Slow Speeds.
03-01-2008 1:50 PM
Re: Slow Speeds.
03-01-2008 1:55 PM
Chances are that this could be caused by exchange contention, but you're exchange is showing up as "green". If we were to raise this to BT they wouild probably just send it straight back to us as a congestion issue.
Re: Slow Speeds.
03-01-2008 2:15 PM
I'm willing to wait a week or two if needed, see if it sorts itself out.
Re: Slow Speeds.
03-01-2008 2:19 PM
Re: Slow Speeds.
06-01-2008 9:03 AM
Re: Slow Speeds.
06-01-2008 9:28 AM
