Slow Speeds.
- Slow Speeds.
Slow Speeds.
31-12-2007 8:21 PM
My speeds started dropping about 2 weeks ago.
Speedtester reports:
IP profile for your line is - 6500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 7616 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 2536 kbps
Mybroadbandspeed:
Plusnet speed checker:
31-12-2007 19:57:14 - 383.9Kbps
I'm currently using a Netgear DG834G Modem/Router.
Stats:
http://img292.imageshack.us/img292/7127/35220498ip1.jpg
Re: Slow Speeds.
31-12-2007 8:34 PM
http://www.speedtest.net/result/217171866.png
They are really slow
Re: Slow Speeds.
31-12-2007 8:47 PM
http://usertools.plus.net/exchanges/
Also have you tweaked?? see here. If exchange is not congested, post back the results of the tweaktester, and Im sure someone can help, if needed.
http://www.kitz.co.uk/adsl/MTU2.htm
Re: Slow Speeds.
31-12-2007 9:23 PM
Re: Slow Speeds.
31-12-2007 9:51 PM
Re: Slow Speeds.
01-01-2008 6:56 PM
Also whats the quality of your normal phone calls?
The reason I ask is just because when I had speeds as low as them it turned out to be the BT box, if your line was a bit below Parr I could see PN being involved but that DL speeds is only just running.
BTW penfold handy link for kitz bookmarked.
Re: Slow Speeds.
01-01-2008 7:25 PM
This is just getting ridiculas now, getting random dropouts, most of my downloads are getting corrupted, probabley to being timed out.
Re: Slow Speeds.
02-01-2008 10:49 AM
Are you getting physical connection drops?
If that is the case, I would strongly advise trying to use a different filter, ensure that you are connecting to your master socket (via filter) and try a different modem or router if this is at all possible.
If you're still having problems we can then raise it with BT as an intermittent fault.
Re: Slow Speeds.
02-01-2008 12:24 PM
I too have been experiencing slow connection speeds of late. My router was reporting a connetion speed of 3500kps and now it's down to 358kps. I've changed my router and filter but to no avail. I've had PlusNet look in to it and they tell me there is no problem with my line. If I want to take it further and have BT investigate further then I run the risk a bill of £144+VAT should BT not find a problem. I'm convience that there is something wrong somewhere that is out of my control, but at the same time I don't want run the risk of getting that bill.
Strange thing is though why when I was getting a connection of 3500kps has it just suddenly dropped to 358kps? I was told if I disconnected the router 5 days in a row it would initialise a routine run by BT similar to what every ADSL connection goes through in the first 10 days - it's didn't and I'm stuck now with a slow connection.
Re: Slow Speeds.
02-01-2008 1:37 PM
Have you been seeing those sync speeds consistently? If so, then it is below BTs acceptable limits which would mean that a fault should be raised if you have done the usual hardware and wiring checks (which you appear to have done) and I'd reccommend the engineer visit. You'll only be charged if the problem is past your master socket (ie: cabling, filter, router).
Re: Slow Speeds.
02-01-2008 1:46 PM
In that case I'll take it further as nothing in the house (wiring, routers etc) changed before the problem started. From what you have said, it would appear I won't be charged as it looks like there is a problem on BT's side of things!
Re: Slow Speeds.
02-01-2008 1:50 PM
I've just sent the fault through to BT for further investigation.
Re: Slow Speeds.
02-01-2008 1:55 PM
Re: Slow Speeds.
02-01-2008 2:24 PM
I was aware of the call out charge but TBH the guy was alright about it, I just told told him to take out the extension as I didn't use it anyway and he fitted a new box.
If you want to be doubly sure take your modem,filter and cable round to a friends and test then you can rule them out.
Re: Slow Speeds.
02-01-2008 5:15 PM
IP profile for your line is - 5500 kbps
Actual IP throughput achieved during the test was - 662 kbps
