Slow Speeds - awful upload (2nd edition)
ax429
Hello,
So I have been with Plusnet for over 6 months now. I have already posted a complaints and I am generally not too happy with the quality of the broadband and its consistency.
I used to have 10M down 0.8M up (which is far worst that what I had with Sky btw) but at least I could live with it.
However I have noticed a significant decrease of my broad band speeds for the last 10 days: 2.9M down, 0.3M up. Which is a problem just for browsing.
I have already rebooted the rooter multiple times but still suffer bad speed.
Why is that? How can you or I fix it?
Alternatively, is it possible to get a refund on the line I have rent for 1 year and paid in advance?
JayG
Re: Slow Speeds - awful upload (2nd edition)
Rebooting your router multiple times in a short space of time will definitely not help matters.
Your previous thread on this subject finished with a suggestion that you try to eliminate the possibility of problems with your extension cable by plugging  directly into the test socket.
Did you try that?
Fixes: 136
Your speeds are pretty poor at the moment.
I'd recommend running through our troubleshooter using the link below to rule out any issues with your internal wiring.
https://faults.plus.net
 Matthew Wheeler
