Quick heads up, following this problem earlier this afternoon:
http://usertools.plus.net/status/archive/1294764656.htmA few people might be seeing slow speeds, the network is quite a bit out of balance and we are trying to get it back but if you see slow speeds tonight try disconnecting and reconnecting first and see if that makes a difference as you may be on a congested part of the network and disconnecting/reconnecting should get you on a quieter part of the network.
Dave Tomlinson
Plusnet Technology
