Slow Speeds Still
stewbett
Slow Speeds Still
Hi i reported my fault 10 days ago and was told the matter would be passed straight to bt as the fault appears to be the same as last time, (slow speeds 0.33 mb.s download and upload and disconects). However bt have not been informed and instead i was sent a new router but the new router has done nothing, so i am still at the same point as i was 10 days ago. Last time i had to wait nearly a month and had 4 bt engineers out before the fault was traced to the exchange.
[Moderator's note by Jim (Oldjim)  All caps in title removed as per Forum Rules ]
stewbett
Re: Slow Speeds Still
Fixes: 58
Can you post the router stats
stewbett
Link Information
Uptime: 0 days, 16:39:33
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 576
Output Power (Up/Down) [dBm]: 12.0 / 17.5
Line Attenuation (Up/Down) [dB]: 23.5 / 44.5
SN Margin (Up/Down) [dB]: 16.5 / 29.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 8 / 0
CRC Errors (Up/Down): 8 / 5
HEC Errors (Up/Down): 612 / 2
jojopillo
Hi stewbett,
I've just nudged one of our faults guys, he's going to look at it for you so there should be an update soon.
Jojo Smiley
stewbett
a nudge? lol give him a push, does the router report show anything out of the ordinary ?
Fixes: 45
Yep, looks like a banded ( 288-576 ) profile to me...
jojopillo
Hi stewbett,
He's just updating the ticket then he's gonna give you a call.
Jojo Smiley
Fixes: 45
Above and beyond the call of duty there Jojo Smiley
jojopillo
Hey Mister W,
At the end of the day I might not be in work or getting paid but I've been through some of the same troubles with broadband connections myself in the past so if I can make a slight difference then that's enough payment for me.
Jojo Smiley
stewbett
thnks for that he called just after your post, they think its the data managment at the exchange so want to see how it goes over the next 2 days.
jojopillo
Hi stewbett,
That's fab, just glad we could get some update for you and move forward a bit.
Jojo Smiley
stewbett
ok been a few days now still nowhere near my normal speeds, not had any disconections but speed has hardly improved.
jojopillo
Hi stewbett,
I have applied for the banding to be removed so that we can see how high you can sync, as you are now syncing at the highest part of the banding. This has now been done and should take effect in a couple of hours. I'll check in later tonight and see how you're doing.
Jojo Smiley
stewbett
Hi jo no improvement  Embarrassed  i am no phone eningeer but the last bt engineer that came out when my up load and download were about the same as this, went to the exchange and the problem was solved and i had no prblems for a few months.
