Slow Speeds ( SOLVED )
Steve
Seasoned Pro
Just read the service status and am aware things will be slow due to the england game? Well i wont watch the game so why should my speeds suffer?
You are currently connected to the "City Lifeline, Juniper 11" gateway. This gateway is sometimes known as pcl-ag04.
If life gives you lemons, make lemonade.
neil3045
Re: Slow Speeds
Same here, my connection has gone from 7 mbps to less than 1 in the last few weeks!!!
Steve
Seasoned Pro
Re: Slow Speeds
My speeds are usually fine and my line is usually 6.5mb, Yep im synching fine with no disconnections or anything!! Uptime 134hrs and counting....
jojopillo
Re: Slow Speeds
Hi Steve M,
We can only apologise for the inconvenience as on the service status, as you can appreciate these are exceptional circumstances and we do expect things to settle back down shortly.
Jojo Smiley
Steve
Seasoned Pro
Re: Slow Speeds
Wonder if it would be the same if scotland were playing!!! Thanks for the reply jojo.
jojopillo
Re: Slow Speeds
...erm, no comment Wink
James
Re: Slow Speeds
Quote from: Steve
We have the Scottish to thank for high usage when Murray is playing at Wimbledon Smiley
jojopillo
Re: Slow Speeds
Hi neil3045,
I see you're in the process of raising a fault, so as you are waiting for that to be investigated you may like to view this link;
http://community.plus.net/blog/2007/07/02/broadband-speed-faults-how-to-diagnose/
it's packed full of information and should answer many of your questions about speed issues.
Jojo Smiley
Steve
Seasoned Pro
Re: Slow Speeds
I dont like tennis, Hope Engerland wins after all this!! Grin
neil3045
Re: Slow Speeds ( SOLVED )
Hi jojo I didnt mean to raise the fault lol I just clicked the line checker to make sure there wasnt a problem with my line coz falling from 7 mbps to less than 1 seemed pretty drastic! Anyway the footballs finished and I just done a speed test and I back to 6.7 again!  Smiley
jojopillo
Ah, it's ok neil3045, the fault won't progress if you don't complete the questions, it will just automatically close anyway. Glad to hear it's back up though. Football, tut!  Wink
