Slow Speed started tonight.
- Slow Speed started tonight.
07-04-2015 1:11 AM
My speed has dropped from 15mb to less than 2mb tonight. I have a few images of information that was suggested to provide for the forum to assess why I might be getting such low speeds.
Ive attached them to this post. Just really wondering why its dropped so dramatically
Many thanks and if any more information is needed I would be happy to help!
Re: Slow Speed started tonight.
07-04-2015 9:25 AM
That increased this morning so the connection should be fine now.
Let us know if you still have any issues.
07-04-2015 1:22 PM
Are there any indications as to why the profile was too low? Does it point to the line having being in difficulty and a lower profile delta report being passed to PN?
Kevin
07-04-2015 1:50 PM
07-04-2015 3:03 PM
Many thanks again!
07-04-2015 3:09 PM
07-04-2015 3:14 PM
dick:quote
07-04-2015 3:25 PM
07-04-2015 6:42 PM
You pack age is up to 16Mbps. You will get whatever your line is capable of delivering.
08-04-2015 9:01 PM
08-04-2015 11:44 PM
I'm sure CRT will pick this up in the morning and get it sorted...
09-04-2015 10:33 AM
The order completed yesterday and the upload is showing as uncapped.
I think the image above was back from when the OP first posted
09-04-2015 11:03 AM
Yes that is right. Revised stats would be useful.
The DS synch is about 3Mbps less than the reported attenuation would lead one to expect. Is the router plugged into the master socket? Are there any extensions, if yes how are they wired? What kind of master socket do you have?
Is there any noise on the line? Dial 17070 option 2 using a corded phone plugged into the master socket.
09-04-2015 4:16 PM
Quote from: Townman Hi Coatseh,
Hiya.
The router is plugged into the master socket. There are no extension. I'm not really sure what master socket types are available? its just one that links in with a phone line. I don't think there is any noise on the line.
Ive attached updated router stats from today. Hopefully better now?
09-04-2015 4:20 PM
Please check the phone line for noise.
