Slow Speed since last night / this morning
- Slow Speed since last night / this morning
Re: Slow Speed since last night / this morning
06-03-2015 10:46 AM
06-03-2015 10:59 AM
Yep, plusnet portal still showing 7.15Mbps, Althought BTw diagnostic speed test still errors.
The router was showing as connected but I had no connectivity at all, so I gave it a reboot.
I believe Chris was due an update from the 20CN capacity management team regarding the exchange.
Daniel
11-03-2015 1:09 PM
Just an update on this.
All weekend speeds on the new VP were top notch 6.6x mb/s was fantastic.
Last night speeds had slowed down to 6.00mb/s over the peak period, not that I am complaining but I just hope it isn't a sign of things to come!
I did notice that the SNR margin on my DS had gone from 13.x to 14.x.
BQM is still a bit messy but loads better than it was.
I will post my router stats etc when I am back home.
Thanks again
Daniel
11-03-2015 9:31 PM
Further diagnostics on the BTw speed test still not working.
Router stats
Current line speed:
7.15 Mb
BQM snapshot
I know its not as bad as it was but the drop off from over the weekend and Monday is quite something.
Daniel
12-03-2015 9:47 AM
Any news on the CVLAN rebalancing? Is CVLAN congestion still thought to be the cause of the horrible TBB BQMs and slow data speed or are we looking for something else? Is CLT still good post the TPM problems?
Does the continued failure of the BT Further Diagnostics test have any material bearing on the general operation of the service?
@Daniel,
Just confirming - are those speed tests over a wired or wifi connection?
Kevin
12-03-2015 10:05 AM
12-03-2015 10:48 AM
Happy to learn the correct terminology...
12-03-2015 11:40 AM
For FTTC/P, the CVLAN is the connection from either the FTTP modem or the FTTC DSLAM to the layer 2 switch in the exchange - this is Openreach's responsibility.
For 21CN ADSL/FTTC/FTTP, the SVLAN is the connection from the layer 2 switch to the BRAS/MSE - this is BT Wholesale's responsibility.
With 20CN, the SVLAN is known as the VP.
12-03-2015 11:54 AM
This is one of the things I love about this community forum - an opportunity for us to all learn and share knowledge, without the fear of being flamed for making a mistake or two along the journey.
Thank you,
Kevin
12-03-2015 12:00 PM
There is somewhere a really good document that explains/shows how quite a few things work. It's lengthy, but the flow charts are really useful to understand the different networks and components.
13-03-2015 11:57 AM
Yep through a wired connection.
Speed was back down to 3.2mb/s when I checked last night.
Daniel
13-03-2015 12:56 PM
These speed tests are highly variable (as we know these beasts can be) and the BQM "mess" seems to extend from 13:30 to 02:00 which is somewhat outside of the time-slots one would expect for pure VP congestion. Could there be some other factor at play here?
Is there anything which can be done to fix Daniel's BTw Diagnostic Test failures so that he can speed test and PlusNet can see the trends?
Kevin
13-03-2015 6:31 PM
13-03-2015 6:34 PM
Quote from: StingA When I do the futher diagnostic test it errors, it has done this as long as I can remember.
Hi Tony,
Good to see an update from you on this one. When you say "Full BT Speed Test" do you mean the further diagnostics bit... which is not working on this line?
Kevin
13-03-2015 6:35 PM
