Slow Speed DLM Line Reset
mrluke
Just changed over from BT to Plusnet . The transition was pretty good , But ! my speeds are exactly the same 21-23mbit .
My line speed when i first joined BT was around 35mbit  ( Which then when down and down )
I assumed when i joined plusnet they would do a DLM reset on the line to assess the speed the line is capable of .
My Line is pretty simple . Copper straight into the BT NTE5c Mk4 , and from there straight into the Hub 2. No internal  phonelines are connected in my house.
I run the Hub2 in "Bridge" mode and then straight into my router ( Ubiquiti UDM Pro ) . The speed is still an issue even when just using the router without being in "Bridge Mode" ( so i know its not my setup ).
Is someone able to do a DLM reset on my line please ? so i can obtain a better speed.
Luke
20 REPLIES 20
mrluke
Re: Slow Speed DLM Line Reset
Heres my line stats . Says on there the max observed speed is 27mbit from today ( Which i dont believe is correct ) ALso states my upload speed has been observed at 5mbit, which to be honest i seem to be getting slightly higher.
willcutforth
Fixes: 113
Hey there @mrluke just done a DLM reset now for you to see if it helps. I couldn't see what it was showing at from our side so I just reset it to 6dB.
Let me know how it performs from there.
 Will Cutforth
mrluke
Thanks , Will check over the next few days to see if there is any increase.
Many thanks
Luke
willcutforth
Fixes: 113
Awesome I will get back to you on Monday.
 Will Cutforth
SammyM
Fixes: 101
Hiya @mrluke
Will is off today and has asked me to check in with you, how's the connection been?
 Sammy M - Sheffield Team
mrluke
Thanks for the followup .
Sadly no speed increase, the connection seems stable but hasn't budged an inch on speed.
Could this be a line problem ?
Luke
RealAleMadrid
Aspiring Hero
Fixes: 62
@mrluke Have you powered down the router and restarted it so the line resyncs, you may find the speed is better.
mrluke
Thanks for the info.
Just rebooted the modem,
A moderate increase on the download speed, an increase from 22-23mbit to 25mbit.
As i have the hub in modem mode i cant see the sync speed sadly.
Fixes: 96
As I have the hub in modem mode i cant see the sync speed sadly.
It is possible to retrieve the line stats from a Hub Two in bridge mode.
You need a a PC running Windows or Linux importantly a wired network connection and a Cat5e cable.
If you have I'll provide the details tomorrow
Dan.
mrluke
Dan , Is that directly connectings my pc to one of the lan ports , Setting the pcs ip address manually and trying to connect to 192.168.1.254 ?
Fixes: 96
Yes, that's the way to do it.
You go to Advanced Settings >Technical Log >Information. you can all also view the event logs,
Note the log starts from 01 Oct as in bridge mode the NTP server is unreachable
HTH
mrluke
Thanks , in the end it was quicker for me to put it back in router mode.
Seems im getting the exact minimum download speed as stated by plusnet ? Has this been capped ?
It states in my broadband speed email
Minimum Guaranteed Speed: 27.4Mb
But states also peak download rates
Download: 31 - 45Mb
how am i able to get this if im capped at 27.4 ?
csmith94
Fixes: 31
Hi @mrluke
Checking over your line, the DLM reset Will put through doesn't seem to have taken and nothing has been updated. What I'm doing is putting this through again as your line in general is fine with no faults.
Give it a day or two and check the speeds, if nothing is improving then we might need to get an engineer out to you
 Curtis Smith
mrluke
Thanks Curtis , Does the modem require a reboot ? or just leave it running.
