Slow Slow unable to use
stathe
Re: Slow Slow unable to use
Thank  you
Fixes: 348
Glad to hear your speed has improved!
No problems. Just out of interest, what was the call with the adviser about?
I don't believe there would've been any ill intent with moving the SNR upwards.
Generally a 3db target can cause issues but in your case it looks like to be a good thing. Thumbs Up
stathe
As my slow slow is still open, I had a query about my payment which was overcharged due to the line rental in advance , He said it wasn't and I should phone I pointed out his mistake with invoice numbers and then he said he had readjusted my line as he had tested it again  I am to get a credit for the overcharge Thank you
stathe
Summarysnr low for the legnth of lineso i have increased this
I will look into the customer service issue to try and resolve
Kind regards,
[CSA Removed]
Moderator's note by Dick (Strat): CSA name(s) removed (to an area staff can see) as per Forum rules.
richi
@Gandalf wrote:
Here's a copy of our test results:
I just went back to @Gandalf's reply from a few weeks back. I noticed what looks like a capped or banded upstream (assuming the ADSL2+ notation is correct): 13 dB margin vs. 6 dB target.
I doubt this is causing the problem, but would it hurt to uncap it?
xDSL Status Test Summary
Sync Status: Circuit In Sync
General Information
NTE Status: NTE Power Status: PowerOn Bypass Status:
Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 43.7 69.0
SNR Margin: 13.4 3.1
Errored Seconds: 0 1
HEC Errors: 0
Cell Count: 0 0
Speed: 446 2353
Maximum Stable Rate (KBPS): 1728 Fault Threshold Rate (KBPS): 1382
Mean Time Between Retrains (Seconds): 86400 Mean Time Between Errors Upstream (Seconds): 46800
Indicative Line Quality: G Mean Time Between Errors Downstream (Seconds): 6686
Profile Info: WBC 160K - 24M Medium delay (INP 1) 3dB Downstream, 448 Low delay (INP 0) 6dB Upstream (ADSL2+)
Fixes: 348
Thanks for spotting this @richi
From what I can see the circuit is provisioned on an uncapped upstream so it's possible it's being capped by DLM.
I've made the change now and looks like the upstream sync rate is now 745kbps but it's pushed the downstream down to 2118kbps. Happy to cap your upstream speed again if you want @stathe?
stathe
Thanks for your help I dont understand  you     but it is working reasonably just below 2 Thank  you I would of course like it faster bur realise the long line prevents it
Fixes: 6
Not that it helps with current problems but have you tried the following to see if anything is planned for your location.
https://www.openreach.co.uk/orpg/home/index.do
Fixes: 55
Hi  stathe
I'm just doing a bit of follow-up on this and it looks like the changes Anoush made to your connection did the trick and I'm seeing the same speeds he mentioned on results of a line test that I've just performed.
 Adam Walker
