Slow Slow unable to use
- Re: Slow Slow unable to use
09-03-2018 7:14 PM
My speed has become very very slow today despite my router speed being as usual very little will work problems doing this
10-03-2018 10:15 AM
This is still very slow and barely works despite plusnet doing things to it
11-03-2018 9:59 AM
The situation is still the same despite my contact by phone yesterday and the day before and doing as instructed
11-03-2018 12:28 PM
12-03-2018 10:10 AM
Well I have done all that and it is still very slow
12-03-2018 7:07 PM
something wrong with my Plusnet I should be able to get 2 at least
13-03-2018 2:44 PM
Hi @stathe
Can you run a BT speedtest at http://www.speedtest.btwholesale.com using a wired connection, completing the further diagnostics at the end? This will store the result on the supplier system and will help us if we report a fault to our suppliers.
Let us know how you get on.
13-03-2018 4:53 PM
13-03-2018 4:59 PM
This is how it is not always as good as the previous one and does not complete properly but
1. Best Effort Test: Download Speed : 1.11 Mbps 2. Upstream Test: Upload Speed : 0.03 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information. |
13-03-2018 5:03 PM
I am unable to complete the test as there is something wrong Thank you
14-03-2018 2:38 PM
Sometimes the test can fail like that. It's not indicative of a fault with your service.
It's just the wholesale test itself not working as it should be.
Testing your line now there aren't any errored seconds showing and your router is in sync at 1.9mbps which is within expectations of your line shown at www.dslchecker.bt.com
The result from the speedtest you've done is about right for the sync rate.
Your connection is also a lot more stable in recent days:
Did you plug your router into the test socket?
24-03-2018 4:53 PM
Unfortunately things are not getting any better the tests dont work and I get the impression that you think it may be my kit I think the bt test should work and the fault may be in the line Yes I have used the test socket
24-03-2018 9:40 PM
1. Best Effort Test: Download Speed : 1.2 Mbps 2. Upstream Test: Upload Speed : 0.11 Mbps
26-03-2018 11:55 AM
As @Gandalf advised the speeds are within the estimates for the line and as such there isn't much further we can do.
26-03-2018 7:15 PM
Well I dont find that Helpful it is obvious to me that this is not working as it should I have previously had speeds approaching 2 fairly consistently and have not been told "bad luck old chap " those are the rules I dont believe things have changed to down grade my connection The BT tests dont even work properly
