Slow Fibre
katief
Slow Fibre
We have noticed a drop in speed over the last couple of months - can anyone help? Getting desperate now!
Computer numpty so be gentle with me!
All4One
Re: Slow Fibre
Any speed results? Have you test via wifi or ethernet? Double checked any random background programs etc?
katief
Re: Slow Fibre
Managed to run test wifi via bt wholesale
10.43 download
0.71 upload
Ping 55.5
All tablets etc off - only one laptop - sky not on demand!
Twills
Re: Slow Fibre
Hi Katief,
Can you run the same speed test via ethernet cable to the router please. Could be a potential wireless problem.
Twills.
Fixes: 62
Re: Slow Fibre
Also after the test has run select further diagnostics and report the result
katief
Re: Slow Fibre
Is says the acceptable range of speed for my line is 7.72 Mbps - 11.03 Mbps
When our fibre was first installed we had faster!
Upload is 0.71 Mbps but it says our upstream rate  is 20mbps !
What is going on?
katief
Re: Slow Fibre
Sorry didn't realise people had posted replies - off to find Ethernet cable! Be back shortly!
katief
Re: Slow Fibre
Same results via Ethernet cable! Weird......
Any suggestions?
katief
Re: Slow Fibre
Should I log an incident thingie?
Fixes: 62
Re: Slow Fibre
raise a speed fault here https://faults.plus.net
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Slow Fibre
Hi katief,
I'm sorry to hear of the issues that you're experiencing. We've received your Fault Ticket (Ticket: 86444927). We'll get you an update on this within the next 24-48 hours.
Chris Pettitt
Cloud Environments Engineer
katief
Re: Slow Fibre
No news and tonight I am thinking of getting a 3G dongle as I am now under 1mb! So slow it's painful!
Certainly not receiving the fibre broadband I am paying for!
Cry
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Slow Fibre
Please allow us some time to investigate this issue for you. As I've mentioned above, we'll be in touch as quickly as possible.
I appreciate it's frustrating when you have a fault with the service - we just want to make sure that we do everything we can to get the fault fixed ASAP.
Chris Pettitt
katief
Re: Slow Fibre
Still heard nothing!
Come on Plusnet you used to be sooo good!!! What's going on? Wink
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Slow Fibre
I've just given our Faults Team a nudge to get this picked up for you. You will hear something back on this today.
Chris Pettitt
