Slow Fibre speeds 16Mbps - should be 40mbps - 80mbps
- Slow Fibre speeds 16Mbps - should be 40mbps - 80mb...
06-05-2012 1:19 AM
I am currently getting a downstream speed of 16.09 Mbps on my Fibre 40 package / Trialing Fibre 80 Mbps.
Has been like this for past 24hrs.
Any ideas?
Any ideas?
Message 1 of 2
(1,029 Views)
1 REPLY 1
Re: Slow Fibre speeds 16Mbps - should be 40mbps - 80mbps
06-05-2012 2:20 AM
Hi active8,
I've just made a slight change to your profile, can you please perform a Speed Test again for us please so we can take a look to see if that has resolved the issue for you?
I hope that has resolved the problem for you
Message 2 of 2
(227 Views)
