Slow Download Speed
shivers
Slow Download Speed
Plusnet tells me that my download speed is 11.4mb.  I done a speedtest with B.T.  just now and they say my speed is actually 4.2mb.  Who is telling the truth.  I have just done speeedtests with others online and it is always coming back as 4.2mb.  My broadband is very slow.
SpendLessTime
Aspiring Hero
Fixes: 53
Re: Slow Download Speed
Hi @shivers
The BTW speedtest is the one that Plusnet will ask you to use if you raise a fault, so that is the one you can go by.
Have you ran the further diagnostics test at BTW which shows your BT IP Profile? Don't change anything on your router even if it asks you to as that changes the network from Plusnet to BT so is not a valid result.
Also the last test ran at the BTW test site can be accessed by Plusnet and it is worth pointing Plusnet to it, if you log a fault.
Another reliable UK speed test is http://thinkbroadband.com if you want a second option.
The fault finder is https://portal.plus.net/apps/kbdfaults if you need it.
shivers
Thanks all who replied.  Tried all recommended and now getting 6.91 donload and .98 upload on some going down to 4.2 upload with ookla.  Really pathetic.   In all other ways PLUSNET has been great and I hope they can sort this.
shivers
Now getting 11.07 and 0.89.
Fixes: 19
@shivers
Please post your router stats; for PN TG582n and 2704n routers use the buttons below, for other routers look at the Kitz link.
Also run a BT Wholesale speed test (ideally using an Ethernet wired PC with the WiFi turned off) then run the further diagnostics and post the results here. DO NOT REBOOT the router!
Also find your CURRENT SPEED (PlusNet line profile) from the PlusNet user portal - you will need to log in.
shivers
Sorry townman.  It is not that I dont want to post them, I don`t know how to.  I have a brain tumour and find it difficult.
Fixes: 19
The links I gave you take you straight to most of the information you need.
The screens displayed can be copied and pasted into a reply here.
