Slow Broadband
g10vanni
Slow Broadband
I'm used to getting a fairly stable broadband speed of arounf 6mbps but have noticed over the weekend that my speed has dropped dramatically
Ran a few speed tests using the link in the
Ping 109
Download 1.99Mbps
Upload 0.65Mbps
any help out there please
5 REPLIES 5
Aspiring Legend
Fixes: 196
Re: Slow Broadband
@g10vanni A suggestion which may help others to help you - have a look at this topic: https://community.plus.net/t5/ADSL-Broadband/ADSL-Speed-faults/m-p/1270245#M297501 and answer as much as you can.
No doubt one of the Help Team will pick this up in time, but their workload is a bit high at the moment
g10vanni
Re: Slow Broadband
Just been on to technical support and they have done a few changes on my line so hopefully things will be up and running soon ( go to reset my router after 4 hours )
Aspiring Legend
Fixes: 196
Re: Slow Broadband
OK - but let us know if you have any further problems - or if the problem is fixed, please.
Tibzor
Fixes: 25
Re: Slow Broadband
Hi @g10vanni
Thanks for getting in touch. I can see that line is stable and speeds are now correct. SNR margin was changed by technical support as mentioned by you and line is performing really good now.
If you will have any further problems, please get back in touch as  stated by @jab1 Smiley
joseflee
Re: Slow Broadband
I try to access website and its shows and error this site can be reached or internet connection error.
