Slow Broadband
- Re: Slow Broadband
Slow Broadband
20-03-2011 4:52 PM
Hi All
I am having problems with my broadband speed .
It has bee running great since I got the last fault fixed but the last couple of days it has starting playing up with speeds on about 400 kbps
Please can you check it out for me.
System Up Time 03:09:50
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 135209 182391 0 1846 15344 03:09:26
LAN 10M/100M 62425 51561 0 4125 965 03:09:46
WLAN 11M/54M 118354 85302 0 11417 988 03:09:36
ADSL Link Downstream Upstream
Connection Speed 4000 kbps 448 kbps
Line Attenuation 50 db 13.5 db
Noise Margin 5 db 20 db
Chris2005
Re: Slow Broadband
20-03-2011 8:03 PM
Today 20:01 196 kbps (24.5kB/s) 369 kbps (46.1kB/s)
Re: Slow Broadband
21-03-2011 11:09 AM
Please can you run a BT speed test at http://www.speedtester.bt.com and paste the results in here? Also have you noticed whether or not the line drops, and if so does it still drop with the router in the master socket and all other items removed from the line?
Re: Slow Broadband
22-03-2011 9:48 PM
I removed everything apart from my pc from router, plugged router into test socket but still have slow speeds.
when I try and do the BT tester it keeps coming back with error.
FAQ
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Regards
Chris
Re: Slow Broadband
23-03-2011 3:01 PM
I've tested the line and can see there's an LTB fault still present so I'll pass this back to our faults team for more investigation (an LTB fault means your line is in sync below the fault threshold rate that was set on your line during the initial 10 day training period).
Re: Slow Broadband
23-03-2011 3:05 PM
Re: Slow Broadband
23-03-2011 11:18 PM
I will get a new router tomorrow and check that first as my router is pretty old ( Netgear DG834G V1 )
Regards
Chris
Re: Slow Broadband
25-03-2011 10:04 AM
I am still waiting on my new router,
Do you know when fibre optic broadband will be available in my area .
Re: Slow Broadband
25-03-2011 5:27 PM
I've done a bit of digging around and it doesn't look like there is currently any dates for an upgrade to fibre on your exchange.
Jojo
Re: Slow Broadband
28-03-2011 11:08 PM
I have reported a fault with my broadband as I am only getting speeds of 400 kbps,
It is similar to the fault I had last time which you rest my line and then the fault disapeared.
Nothing has been changed on my setup apart from buying a different router to try and fix the problem.
I have a message to arrange a call from an engineer to check my home wiring but its hard for me to get time off work for this.
Can you please check from your end as you sorted out the problem last time .
Chris2005
Re: Slow Broadband
29-03-2011 10:53 AM
As our faults team have been testing this and deemed that you need an engineer then I would go with that. If it was something they could have done from this end then they would have done it.
Jojo
Re: Slow Broadband
31-03-2011 8:35 AM
The engineer is due to call today but now this morning the broadband is working fine ,
I dont no if something has been fixed already but its been very slow for a week or so .
Date Download Speed Upload Speed
Today 08:29 2724 kbps (341kB/s) 256 kbps (32kB/s) Share
Monday 08:35 513 kbps (64.1kB/s) 369 kbps (46.1kB/s) Share
Mar 20, 20:01 196 kbps (24.5kB/s) 369 kbps (46.1kB/s) Share
Feb 15, 20:31 131 kbps (16.4kB/s) 376 kbps (47kB/s)
Regards
Chris2005
Re: Slow Broadband
31-03-2011 9:51 AM
Jojo
Re: Slow Broadband
01-04-2011 1:49 PM
All sorted now
Chris2005
Re: Slow Broadband
01-04-2011 4:12 PM
Thanks for letting us know,
Jojo
