Slow Broadband speeds
- Slow Broadband speeds
- « Previous
- Next »
Re: Slow Broadband speeds
23-03-2024 5:14 PM
@JAB @alfie00 Upon testing the broadband the copper line test failed for the following reason;
"Test Result: Fail - Fault located at customer apparatus (appointment required) Description: FAULT - Loop (Rectified)"
The copper line test failure will account for all the issues described. Have you been able to test the phone on its own, do you have 1 to try?
23-03-2024 5:20 PM
26-03-2024 5:32 PM
Hello James,
Did you have the chance to look at the photographs of the wall socket and the router?
Regards,
Alf.
- « Previous
- Next »
