Slow Broadband, High Error Seconds
itsme
Been suffering with stuttering and very slow broadband from this morning. So thought I post my router stats to see if any other user have had similar problems. I'm not losing sync or a drop in sync speed just experiencing 100% error time and high uncorrectable blocks.
As I can use a near neighbour BTFon point I will leave it until Monday to see if it clear itself before jumping through all the hoops to raise a speed fault.
1 REPLY
Fixes: 32
Re: Slow Broadband, High Error Seconds
I've just run a few checks to be on the safe side and can't see any obvious issues. I can see you've raised a fault now so you should receive a reply about that ASAP.
Adam
 Adam Walker
