Slow Broadband Help needed to increase
KitKite
Could someone look at my broadband connection. It's approx 2600kbps when it was 6500kbps and has been approx 8000kbps. Also the connection mode is now G.992.3 when it was G.992.5
Link Information
Uptime: 5 days, 11:20:42
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 1,204 / 2,638
Data Transferred (Sent/Received) [MB/GB]: 257.24 / 3.87
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 22.0 / 39.0
SN Margin (Up/Down) [dB]: 6.1 / 18.3
Loss of Link (Remote): -
Error Seconds (Local/Remote): 25 / 0
FEC Errors (Up/Down): 0 / 2,844,418
CRC Errors (Up/Down): 399 / 31
HEC Errors (Up/Down): 256 / 112
1 REPLY
Fixes: 136
Re: Slow Broadband Help needed to increase
I can see we've updated your fault this morning.
Let us know if you're still having issues
 Matthew Wheeler
