Sky download failure
- Re: Sky download failure
03-04-2014 10:17 PM
We move to Plusnet last night from Orange BB. We have a Sky+ HD box that was used quite extensively for catch up tv. However today we are unable to download any programmes, the reason given is
FAILED REC:HTTP_403_FORBIDDEN
Is this a Sky or Plusnet problem?
We are using a Technicolor TG582n Plusnet router.
Any help very much appreciated
Message 1 of 6
(3,465 Views)
5 REPLIES 5
04-04-2014 10:13 AM
Hi robbiec3,
Firstly welcome to our community forums, it seems your issue may be linked to this thread. If you can log into your router and click disconnect then connect this will hopefully solve it for you.
Let us know how you get on.
Message 2 of 6
(1,747 Views)
04-04-2014 9:27 PM
Hi Chris
Ran a speedtest, speedtest.net, last night which showed my isp as INFONET Services Corporation with an ip 146.200.3.29
Tonight after reading your reply, I did another speedtest with the same result ie INFONET ip 146.200.78.234 I then done a disconnect/ reconnect
I'm still with INFONET ip now 146.200.90.183
Robbie
Robbie
Message 3 of 6
(1,747 Views)
04-04-2014 9:37 PM
They need to update the ARIN database records:
Quote NetRange: 146.200.0.0 - 146.200.255.255
CIDR: 146.200.0.0/16
OriginAS: AS6871
NetName: PLUSNET1
NetHandle: NET-146-200-0-0-1
Parent: NET-146-0-0-0-0
NetType: Direct Assignment
RegDate: 1991-02-28
Updated: 2013-08-29
Ref: http://whois.arin.net/rest/net/NET-146-200-0-0-1
OrgName: INFONET Services Corporation
OrgId: INFO
Address: 2160 East Grand Avenue
City: El Segundo
StateProv: CA
PostalCode: 90245-1022
Country: US
RegDate:
Updated: 2011-11-30
Ref: http://whois.arin.net/rest/org/INFO
Message 4 of 6
(1,747 Views)
05-04-2014 10:32 AM
Hi All
This morning and another speed test and I'm still with INFONET, ip 146.200.35.131. The Sky box can now download Catch Up TV so at least my wife's happy.
Message 5 of 6
(1,747 Views)
07-04-2014 1:48 PM
Hi robbiec3,
We're continuing work on getting the IP issue resolved. I'm glad that your Sky Box can download again now - apologies for the inconvenience caused.
Message 6 of 6
(1,747 Views)
