Sky Go not working
Jinja
Sky Go not working
Sky Go has suddenly stopped working on all our devices with a message that we are in the wrong country to watch live broadcasts although it has worked fine for the last 15 months. I rang Sky and the first thing that they asked me was "Are you with Plusnet" as it is apparently becoming a regular problem due to the address of the broadband appearing to be abroad. Anyone else have this problem or have an easy solution please ?
Re: Sky Go not working
Hi
What does it say for your ISP/Country if you go here http://www.whatismyip.com/ ?
Jinja
Not sure Andy. I am at work at the moment but will have a look when i get home later this afternoon. Just damned annoying that something works fine one day and then not the next, although I have to say that the service delivered by Plusnet over the last 15 months has been excellent.
Mine says "Sheffield". Is that in England?? Roll eyes
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi Jinja,
If you could log into your router and hit the 'Disconnect' button and then 'Connect' again, this should resolve the issue for you. It appears that you've been assigned an IP address that's causing a few issues that we're investigating at the moment. Once your connection drops by doing the reconnect you should (hopefully) be assigned an IP address that isn't affected.
Chris Pettitt
Cloud Environments Engineer
JulianL
Yup same here 'Concurrency limit reached....Content only available in specified countries'
Will try a disconnect and reset
Same here.  Crazy
@ HPsauce - I take it your current IP is in the 146.200.0.0 - 146.200.255.255 range? I thought PN were not longer assigning IPs from this range and it was only customers that had already been assigned an IP that were affected (which should have been fixed by a disconnect/reconnect).
That's what I thought as well, and my connection has been up for less than 2 days.  Sad
Anyway a disconnect/connect fixed it, but I missed Martins Grid Walk on Sky Sports F1.  Angry
Now on the 46.208 range.... (which I thought I was on before as I'm "supposed" to have a static IP!  Shocked )
dragon2611
Interesting, I wonder how many ISP's this is affecting then.
Just Plusnet...
GumDrops
I was having this issue with Sky Go on the 360 before my connection went completely
Yorky23
Mine Sky Go has stopped working on I pad 2 os 7.1.1. Sky says contact your internet provider as they think it is a plusnet problem. We are apparently not in England
If you disconnect/reconnect manually from your router admin page, the problem should go away.
Yorky23
Working. Just reset my router
