Sky Go not working
- Sky Go not working
Sky Go not working
02-05-2014 8:54 AM
Re: Sky Go not working
02-05-2014 8:56 AM
What does it say for your ISP/Country if you go here http://www.whatismyip.com/ ?
02-05-2014 9:00 AM
02-05-2014 10:03 AM
Quote What does it say for your ISP/Country
Mine says "Sheffield". Is that in England??
02-05-2014 10:08 AM
If you could log into your router and hit the 'Disconnect' button and then 'Connect' again, this should resolve the issue for you. It appears that you've been assigned an IP address that's causing a few issues that we're investigating at the moment. Once your connection drops by doing the reconnect you should (hopefully) be assigned an IP address that isn't affected.
04-05-2014 3:59 PM
Will try a disconnect and reset
11-05-2014 12:46 PM
11-05-2014 12:49 PM
11-05-2014 12:53 PM
Anyway a disconnect/connect fixed it, but I missed Martins Grid Walk on Sky Sports F1.
Now on the 46.208 range.... (which I thought I was on before as I'm "supposed" to have a static IP! )
11-05-2014 7:36 PM
11-05-2014 7:55 PM
11-05-2014 8:07 PM
11-05-2014 9:24 PM
11-05-2014 9:26 PM
11-05-2014 9:39 PM
