Sites not loading
cbcadmin
Sites not loading
Anyone have any speed issues with sites not loading?
One example for me atm is http://www.flickr.com
Left to load for several minutes: nothing. Reload, still just a progress bar. Go back to it after posting this and it loads fine.
Keef - Sheerness Kent UK - Plusnet via Technicolor TG582N
Previously - Sky, EE, New Call Telecom/Fuelbroadband, Plusnet, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
Fixes: 67
Re: Sites not loading
Hi Keeef,
We're not aware of any issues that might be causing this for you.
Is it just certain sites or all?
If it's the latter I'd run a speedtest to see if that highlights an issue: http://speedtest.btwholesale.com/
 Adam Walker
Listicath
I'm also having problems, but with http://www.bsfa.co.uk just not appearing at all.
Both http://isitdown.co.uk/www.bsfa.co.uk and http://downforeveryoneorjustme.com/http://www.bsfa.co.uk/ report that it's working...
davidfriedlande
im also having problems with sites not loading, bbc for example
Fixes: 19
Quote from: Listicath
This seems to be a DNS problem, the Plusnet DNS servers aren't resolving the IP address of bsfa.co.uk, and are returning SERVFAIL responses instead.
You may be able to work around the issue by changing the DNS servers used by your computer or router, to Google DNS 8.8.8.8 and 8.8.4.4 or OpenDNS 208.67.222.222 and 208.67.220.220.
Fixes: 31
The sites above work for me, but then I am using a Home Hub 5 with BT's DNS
Cagney1994
Sites working for me too. I'm using the Belkin 150 router (yep, I know, it's a bit cr*p), but it seems to be doing the job. Also I'm using PN's DNS so no issues so far.
Listicath
Switched to Open DNS and it's connecting without any problems now. Thanks all.
cbcadmin
Any update on this please?
Another example this morning :-
https://m.mg.mail.yahoo.com/
marcusk
Quote from: _Adam_Walker_
Hi Keeef,
If switching to an open DNS and having that resolve the issue isn't an indication that there is an issue with Plusnest's default DNS servers I don't know what is..?
More than a few posts on this topic now also with more than a few people having the same issue, and thats just the ones that make their way into the forum, i'll bet most don't.
Fixes: 19
I've not noticed any further specific problems with the Plusnet DNS servers, and bsfa.co.uk has started working with Plusnet DNS now.
Fixes: 89
Would be helpful to get some of the info here if problems persist.
JJ
having same problems. Changed DNS servers to google ones and it now works !!
JJ
Should add it wasn't all sites. What was strange it was the sites I use the most. I would swear they were taking longer to connect each time I accessed them.
pauljeffer
btw running the bt wholesale speed test I get
Download Speed (Mbps) : 0.00
Upload Speed (Mbps) : 15.30
Ping Latency (ms) : 27.38
