Sinking profile/ speed
- Sinking profile/ speed
Re: Sinking profile/ speed
05-09-2007 4:06 PM
You would need to maintain those sync speeds for about 3 days for a profile change to be made at BTs end.
07-09-2007 10:59 AM
Raised ticket today
Quote from: James Hi Lucerne,
2 Ticket no. 2791370
On the last few (over 3) days I have been syncing in the high 5000s and with SNR over 9 (sometimes over 10) but have only seen speeds in the
3700s. Can you look in to my connection to see if the SNR might be reduced and my profile adjusted, as the speeds I now see are well below those achieved in the past. Thank you.
I hope what I put is what I should have.
07-09-2007 11:14 AM
I've replied to your ticket with some good news
07-09-2007 11:47 AM
Quote from: PJ The target SNR for most MaxDSL lines in 6dB- this is intentional and MaxDSL is reliant on this in order to deliver the higher speeds.
I find that very interesting and something I've always wondered about is; is there a definitive way of ascertaining what your target SNR actually is.
I ask this because I have 2 routers, a Netgear DG834 and a BT Voyager 210 and something's puzzling me. When I plug in the Netgear, it always starts up with a noise margin of around 9dB but when I plug in the Voyager, it always starts up with a noise margin of around 6dB. I would have thought that both routers should start up with more or less identical noise margin.
Regards .....
07-09-2007 11:58 AM
Thanks James-
Quote from: James Hi there,
last PN speed test 4716/381 with SNR 9.2. Still scratching sandbox atop my shoulders what made it go down from 5500 on 15/8 to 4000
11-09-2007 7:37 AM
Immediately after James advised me that the profile had been reset speeds were over 4500 but soon moderated to 4200. However last night and this morning they were very erratic and dropped well below 4000with lows below 3000. Is there any significance, or could the cause be within my computer?
Date Time Download Speed Upload Speed
29-Aug 07:09 4281 kbps (535.1 KB/s) 381 kbps (47.6 KB/s)
4-Sep 13:43 3795 kbps (474.4 KB/s) 380 kbps (47.5 KB/s)
4-Sep 17:42 3764 kbps (470.5 KB/s) 381 kbps (47.6 KB/s)
5-Sep 06:11 3778 kbps (472.3 KB/s) 381 kbps (47.6 KB/s)
5-Sep 09:21 3767 kbps (470.9 KB/s) 381 kbps (47.6 KB/s)
5-Sep 12:36 3764 kbps (470.5 KB/s) 380 kbps (47.5 KB/s)
5-Sep 15:29 3793 kbps (474.1 KB/s) 381 kbps (47.6 KB/s)
5-Sep 22:13 3777 kbps (472.1 KB/s) 381 kbps (47.6 KB/s)
6-Sep 13:21 3790 kbps (473.8 KB/s) 381 kbps (47.6 KB/s)
6-Sep 16:12 3786 kbps (473.3 KB/s) 381 kbps (47.6 KB/s)
6-Sep 19:55 3766 kbps (470.8 KB/s) 381 kbps (47.6 KB/s)
7-Sep 07:42 3797 kbps (474.6 KB/s) 381 kbps (47.6 KB/s)
7-Sep 10:31 3769 kbps (471.1 KB/s) 380 kbps (47.5 KB/s)
7-Sep 11:51 4716 kbps (589.5 KB/s) 381 kbps (47.6 KB/s)
7-Sep 19:12 4705 kbps (588.1 KB/s) 381 kbps (47.6 KB/s)
8-Sep 07:05 4273 kbps (534.1 KB/s) 381 kbps (47.6 KB/s)
8-Sep 10:00 4280 kbps (535 KB/s) 381 kbps (47.6 KB/s)
8-Sep 17:42 4267 kbps (533.4 KB/s) 381 kbps (47.6 KB/s)
9-Sep 14:03 4285 kbps (535.6 KB/s) 381 kbps (47.6 KB/s)
10-Sep 07:34 4241 kbps (530.1 KB/s) 381 kbps (47.6 KB/s)
10-Sep 15:24 4265 kbps (533.1 KB/s) 381 kbps (47.6 KB/s)
10-Sep 19:53 4296 kbps (537 KB/s) 372 kbps (46.5 KB/s)
10-Sep 20:31 2754 kbps (344.3 KB/s) 245 kbps (30.6 KB/s)
10-Sep 20:38 4137 kbps (517.1 KB/s) 354 kbps (44.3 KB/s)
10-Sep 20:40 3051 kbps (381.4 KB/s) 257 kbps (32.1 KB/s)
10-Sep 22:01 4280 kbps (535 KB/s) 381 kbps (47.6 KB/s)
10-Sep 22:40 4256 kbps (532 KB/s) 381 kbps (47.6 KB/s)
11-Sep 06:14 3782 kbps (472.8 KB/s) 373 kbps (46.6 KB/s)
11-Sep 06:29 3770 kbps (471.3 KB/s) 373 kbps (46.6 KB/s)
11-Sep 06:43 3789 kbps (473.6 KB/s) 373 kbps (46.6 KB/s)
11-09-2007 9:38 AM
I'm trying to find out your current sync speed but the BT site is being a little slow.
11-09-2007 9:53 AM
11-09-2007 10:39 AM
11-09-2007 10:40 AM
Some unlucky people connected to the Sheffield Cutler exchange (ie: me) see peak speeds considerably different to off peak. It just depends on the exchange that you are connected to.
18-09-2007 7:10 AM
I am completely puzzled, as apart from examining the sockets and finding out that the previous occupant's bell wire had been removed and replacing socket http://community.plus.net/forum/index.php?topic=1572.msg14911#msg14911
all remains the same. Test results and line stats are attached
18-09-2007 9:49 AM
Line Rate: The line rate has varied by a considerable amount and very often on almost all days during the analysis period. The line rate is within acceptable limits. Please see the average value.
SNR: The noise margin has varied by a considerable amount but occasionally on just a few days during the analysis period. This is normal behaviour for a DSL product and is not affecting the service in any way.The Noise margin is within acceptable limits. Please see the average value.
This could well be expected behaviour for the length of your line to your exchange. The fluctuations are most likely down to your margin variations, potentially causes by some poor quality on the line. I don't think it's related to the bell wire.
18-09-2007 10:11 AM
Some time before the SNR was much less than 15+ and I never noticed much of a problem with my connection. Would it be possible and worthwhile to request a reduction?
You write "see averages". May be it's one of my Specsaver moments , but no can see. Did you perhaps mean 'calculate and see'? BTW what length of line do you make it? You also wrote ' a wider problem'---wider than the things you mentioned after?
OT to this, I am mulling over upgrade (see my thread in Community to which you have responded). Might the change and intro of a router make the connection more stable to a worthwhile degree?
If I seem a real dumbo, I am so forgive
18-09-2007 10:13 AM
Sorry - I didn't copy and paste the averages!
It is possible that you may just have to deal with the fluctuations that you are seeing, although it is possibly down to your modem. I'd always recommend an upgrade to a router, because then you're less likely to have software problems and they're generally a lot more stable that a USB Modem, especially as you don't have to reconnect every time that you start up your computer.
18-09-2007 10:27 AM
That will allow you to drop your default noise margin by up to 5dB
