Single threaded downloads pausing (Start ,Stop,) Fault?
- Re: Single threaded downloads pausing (Start ,Stop...
25-04-2014 1:11 PM
As above is it a fault of some kind, i have set up a PPPOE mini port connection using my login credentials to exclude my router from the possible causes but for some reason it will not connect it just keeps on giving some error code any ideas? my O/S is WIN XP SP3 The error code is 769, my lan (via router ) is configured as a static ip to the one pc , and gets it's dns from the router , does the PPPOE miniport need the main lan connection to be enabled as well?
Message 1 of 7
(1,496 Views)
6 REPLIES 6
Re: Single threaded downloads pausing (Start ,Stop,) Fault?
25-04-2014 3:38 PM
does no one know ?
Message 2 of 7
(551 Views)
25-04-2014 3:45 PM
Need to enable the LAN connection.
Message 3 of 7
(551 Views)
25-04-2014 4:13 PM
Here's what i have tried so far, with lan cable in modem, i cleared my manually setup LAN connection config static IP ect, to automatically obtain IP and DNS and was enabled ,but it says that a network cable is unplugged like it isn't recognising that it's connected to the modem. this should of enabled dhcp on my box, this time i think the error was 678 the pc isn't talking to the modem at all for some reason
Message 4 of 7
(551 Views)
26-04-2014 10:12 AM
After having a trawl around so, the search results, re the lan cable unplugged error ,when trying to connect directly to the modem using PPPOE mini port , As iv'e tried a reboot of my pc ,with no success ,could it be that the BTOR modem needs to be power cycled for this to work, I haven't done this because of DLM as it reacts like the bull in a china shop to the slightest problem
Message 5 of 7
(551 Views)
26-04-2014 10:22 AM
Does the LAN port light up on the modem?
Have you tried disabling/enabling the LAN in XP?
Message 6 of 7
(551 Views)
26-04-2014 10:51 AM
I can't remember if the lan led was lit or not, (haven't tested again since yesterday) i think that i did disable /enable the LAN adapter in XP , but still showed the the red X indication of not connected , i also did reboot the pc to no avail, the only thing i ain't tried is a power cycle of the modem, one thing that is puzzling me is, how will this modem give out an IP to my PC as it's just a modem
Message 7 of 7
(551 Views)
