Silly Question!
buseng12
Silly Question!
As the title says it might be a stupid question. I have just received a new router  to replace a suspect one.
With it was a bag to return the old one. It says peel off the "Lift here to return" sticker, where do you put it?
Inside the package or stick it on the outside? I only ask because I do not want to get charged for not returning the router.
Obviously I will get proof of posting.
Cheers.
Re: Silly Question!
Don't worry about the sticker - you're fine to throw it away. We won't consider a router as not returned if it doesn't have the sticker with it Smiley
NorthEasterner
Re: Silly Question!
You can use the existing router if you want to with fibre,
its just the case of loading a fibre firmware, search around the forums, then the modem connects to LAN 4 on 582n
The firmware upgrade only works on the 582n routers not the 585
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
