Silly Question!
- Re: Silly Question!
Silly Question!
13-08-2013 5:40 PM
As the title says it might be a stupid question. I have just received a new router to replace a suspect one.
With it was a bag to return the old one. It says peel off the "Lift here to return" sticker, where do you put it?
Inside the package or stick it on the outside? I only ask because I do not want to get charged for not returning the router.
Obviously I will get proof of posting.
Cheers.
Cheers.
Message 1 of 3
(732 Views)
2 REPLIES 2
Re: Silly Question!
14-08-2013 9:12 AM
Don't worry about the sticker - you're fine to throw it away. We won't consider a router as not returned if it doesn't have the sticker with it
Message 2 of 3
(389 Views)
Re: Silly Question!
14-08-2013 9:48 AM
You can use the existing router if you want to with fibre,
its just the case of loading a fibre firmware, search around the forums, then the modem connects to LAN 4 on 582n
The firmware upgrade only works on the 582n routers not the 585
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 3 of 3
(389 Views)
