Sign in on devices opens router settings page
- Sign in on devices opens router settings page
12-09-2020 11:28 AM
Any device, including my phone, which has connected to their broadband plenty of times, opens the router page when you try to connect. I can't see what's wrong. I've reset the router, restarted it, etc, but no luck. My dad reckons it connects intermittently, but it hasn't since I got here last night.
Any ideas? 🤔
Re: Sign in on devices opens router settings page
12-09-2020 12:07 PM
Do you mean that you can't connect to the router or the router is not connected and there's no Internet on any device?
Either way try a factory reset by pushing a paperclip or similar into the hub factory reset hole and keep the switch closed for about 20 seconds. It should then reset itself, which can take several minutes.
12-09-2020 12:10 PM
That usually means that the router is not connected to the internet
12-09-2020 2:33 PM
12-09-2020 2:36 PM - edited 12-09-2020 2:38 PM
I got screenshots of the settings on my phone, but can't see how to attach them on the mobile site.
12-09-2020 2:49 PM
What are the hub lights showing?
12-09-2020 2:54 PM - edited 12-09-2020 2:58 PM
Devices are saying 'sign in required' rather than 'password required'.
12-09-2020 3:13 PM
With respect your story is extremely confusing.
You said there was no internet and the hub was showing disconnected followed with the TV is connected to the Internet.
Is it just wireless that is not working or is the broadband going up and down, indicated by at the very least the hub b light coming on and possibly the blue light changing to orange?
12-09-2020 3:18 PM
Anyway, they've decided to get rid of their connection altogether, which is actually a relief!
Thanks again for trying to help someone who is confused!
12-09-2020 8:08 PM
