Should my speed be faster?
- Should my speed be faster?
21-01-2012 8:20 PM
Link Information
Uptime:
5 days, 6:05:31
DSL Type:
G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]:
444 / 10,226
Re: Should my speed be faster?
21-01-2012 8:22 PM
21-01-2012 8:36 PM
I did myself once get 86% - early Sunday morning deliberately tested at this time to try and find the true maximum.
You won't actually achieve the IP profile setting as a download speed in actual practice
(stands by for poster to pop up saying they can manage it in the flat above the exchange!)
21-01-2012 8:46 PM
More usually 86.25% daily (17.25mb/s)
I always run the speed test twice, it often gives a higher speed on the second reading.
21-01-2012 8:47 PM
Quote from: x47c
I am only 466 metres from the Exchange ........ I can never move !
21-01-2012 8:59 PM
21-01-2012 10:16 PM
[color=navy]If you can get around 89% of an IP profile be happy (20CN ..... not sure about 21CN)
21-01-2012 10:32 PM
Rather than raising a issue about the actual achieved real life download speed.....
They are raising a question as to why their IP profile on the plusnet member page is 8.4Mbps rather than the 9.0Mbps they would expect from their sync speed of 10K.
They are on 21CN
So as I understand it (I'm not on 21CN so am not sure of my ground!) the IP profile is mean't to be set to 88% of the sync speed with immediate effect.
So the question is actually about the much discussed issue here of 21CN IP profiles not updating.......
22-01-2012 12:49 AM
Yes your Plusnet Current line speed setting in the Member Centre should be 9.0Mbps. I suggest posted details in this *21CN ONLY* Do you think your PN profile is not updating as it should? topic to facilitate Jojo picking it up.
David
22-01-2012 2:44 AM
22-01-2012 9:40 PM
