Should I switch router off
- Re: Should I switch router off
16-08-2013 10:37 AM
Hi, I am going away for a few days and I usually just leave the router switched on, but I've received a letter from the electric people that my supply will be off all day whilst they replace some poles that are rotten, Could anyone advise, would I be better switching the router off before I go ?
The last time it was off the electric was off and on at different stages of the day, I have interleaving switched off as well so don't want the line to think I have problems if that makes sence.
Regards
Jono
Regards
Jono
Message 1 of 4
(756 Views)
3 REPLIES 3
16-08-2013 11:09 AM
If they do more work than planned causing more disconnections, it could be bad for you IP profile. Personally I would turn it off, better one disconnection than a possible number of them that forces the BT system to cripple your connections speed.
That and routers and or its power supply can fail, as they are pretty much on all the time, so a fire risk.
FTTP 500 regrade from Tues 28th November
Message 2 of 4
(475 Views)
16-08-2013 11:12 AM
The other thing is that unplanned (sometimes planned as well but not if they do it properly) power supply cuts can cause power surges which can damage power supplies so I would definitely switch it off and disconnect it from the mains
Message 3 of 4
(475 Views)
16-08-2013 11:56 AM
Thanks, I will turn it off then.
thanks for the advice
jono
jono
Message 4 of 4
(475 Views)
