Should I reset my router?
cakebar
Had one of those spike things that defaulted the bandwidth to barely nothing, I reported the problem and now it's been 3 days, the speed has increased slightly to 236kbps from 130kbps. It's usually around the 2.5mbs mark so I was just wondering should I be patient for a little longer or should I reset the modem to see if it helps now?Smiley
1 REPLY
cakebar
Re: Should I reset my router?
I somehow disabled the router and then logged back in and it's running great again, oh well no need to reset then or maybe that's what I did, who knows. Tongue
