Should I just give up?
- Should I just give up?
09-08-2016 1:56 PM
Finally decided that Plusnet can do nothing to improve my service so probably have to just call it a day.
With only one device connected, problems aren't quite as frequent but, have two or more users connected at the same time and it's dreadful.
Tried connecting straight to the BT master socket for a couple of weeks but same problems.
Gaming on a PS3 can be working fine but when another family member even drives up the driveway with an iPhone in the car, the connection drops. Before they even get in the house!
Very little interest yesterday from tech support, who took the mandatory thirty minutes to answer.
She told me to turn the router off and on again and then we would do a speed test.
ok, I said its on again.
Wait for all the lights to come on then we'll do a speed test she said again
lights are now on I said
ok, we'll do a speed test, she said
silence for several minutes
eventually
are you doing it? She asked
doing what? I asked
ive to do it?
yes
could have told me how!
download speed 12.7
upload speed 0.36
" that's within acceptable limits"
so why doesn't it work? I ask
change the channel setting on the router from "auto" to either 1,6 or 11, she instructed
keep trying different ones to see if it improves, if it doesn't, there's nothing else we can do.
Looks like terminating the contract is all they can suggest too.
Re: Should I just give up?
09-08-2016 3:16 PM
Hi ankado,
Thank you for getting in touch with us via our community forums and I am sorry to hear about the issues you are facing.
From checking your connection and looking at your line stability everything is looking as it should be but obviously depending on what your using the connection for and how many devices are connected can have an adverse affect on your connection. For instance gaming and streaming and downloading at the same time will use an increased amount of bandwidth that on your connection speed won't perform at it's very best. For something like that you would be better off using a fibre connection which is available for you and offers better speeds and stability.
09-08-2016 7:19 PM
Upload speed looks a little slow. Download may be with expected limits depending on how long your line is. However if your line's running at 12 meg and you're finding it unusably slow, maybe there's something else going on. Are you accessing over wireless or Ethernet? Are you sure nothing's running in the background, iPhoto or iCloud backup, Google Drive Sync or similar?
When you say a "connection drops" what actually happens?
09-08-2016 7:45 PM
Thanks for the replies.
All our devices connect wirelessly.
When I say the connection drops, the game freezes and a broken connection symbol appears on the screen ( it's a PS3). At other times the game "stutters" and characters don't move around smoothly.
Even when not gaming, two or three people just browsing Facebook can have to wait ages for pages to load.
09-08-2016 7:46 PM
I understood that a fibre connection wasn't an option?
09-08-2016 8:48 PM
If you want to find out what services are available for you, just enter your phone number at http://www.dslchecker.bt.com/adsl/ADSLChecker.Telephone?URL=&SP_NAME=a%20service%20provider&VERSION=...
10-08-2016 8:49 AM
Thanks. Had a look at that but doesn't mean much to me I'm afraid.
10-08-2016 9:55 AM
If you copy the output and remove your phone number from it, then someone here will be able to tell you what it means.
10-08-2016 10:23 AM
I have experienced exactly the same issue and have found the problem rests with the wireless function of my modem/router and nothing to do with Plusnet delivery of Internet services.
It is curious to me that it 'seems' Apple products are the cause. I have no issues with Android/Windows tablets or phones - only the iPhone and iPad trying to access my internet wirelessly. On doing so they crash my Belkin modem/router sometimes immediately, sometimes after a few minutes and I have to restart the modem/router to get back on-line. I can have multiple Windows laptops running wirelessly at the same time without any problem.
I would suggest you replace your modem/router as this is likely to resolve your issue.
10-08-2016 10:40 AM - edited 10-08-2016 10:41 AM
Looks like it's capped to me!. I would suggest the first thing is to get that uncapped, surprised no-one at PN has done that already!.
Don't know much about iPhones but it sounds like it may be uploading a lot when it connects (synching/backup perhaps?). This could well be flooding the upstream and affecting other devices. Uncapping will only give a doubling of the upstream at maximum but may be enough to not affect other devices as much.
OR I could be barking up the wrong tree...
10-08-2016 10:48 AM
What router do you have? If it is a dual band (2.4GHz and 5Ghz) then it may help to have different SSID names on the 2 bands.
10-08-2016 10:09 PM
Here it is
10-08-2016 10:11 PM
I did suspect at one time that it was just some sort of incompatibility with Apple products as problems are much worse when they are also online.
My router is the standard Plusnet one that they give you and is fairly new.
10-08-2016 10:17 PM
its the one issued by Plusnet.
A Sagemcom 2704N.
Don't know if it's dual band or not.
10-08-2016 10:26 PM
Even as I'm typing this, it's impossible to game on the PS3 at the same time.
