Should I have the red spikes on my think broadband graph
- Re: Should I have the red spikes on my think broad...
28-12-2013 2:53 PM
http://www.thinkbroadband.com/ping/share/6df90b988d6dc53b602ec4c5d6630faa-28-12-2013.html was downloading at these times
Message 1 of 5
(830 Views)
4 REPLIES 4
Re: Should I have the red spikes on my think broadband graph
28-12-2013 9:54 PM
I think the huge increases in ping times while downloading could be due to Plusnet's copy of your IP profile being higher than it should be. It should be equal to the BT IP profile (maybe rounded down slightly).
Message 2 of 5
(411 Views)
29-12-2013 9:16 AM
10am too11am and 1pm too 6pm, where you downloading anything, e.g. trying a MMO game, running a peer to peer application? As that is what it looks like if using something that uses your complete connection speed, both up and down.
FTTP 500 regrade from Tues 28th November
Message 3 of 5
(411 Views)
30-12-2013 9:14 AM
The profile on our side is set correctly, so that's not the cause.
Are you also uploading at the same time? If so, try limiting the uploading to around half of the maximum and see how that looks.
Message 4 of 5
(411 Views)
30-12-2013 9:48 AM
If you are satisfied with the speed and quality of the downloads then ignore the graph. The chances are that your router was too busy to respond to the pings rather than there was any fault with the connection. Alternately try with a better quality router.
Message 5 of 5
(411 Views)
