Should I do a soft disconnect on the router?
shalom2010
I've noticed in on my High Speed Broadband stats it says:
Estimated line speed:
62Mb (Accurate to within +/- 1Mbit) - Checked on 2013-03-24 09:11:39
Current line speed:
59.8 Mb
I've not had any change in IP address for around two weeks (although on dynamic) + my BT IP Profile is currently 59.8. Should I try a disconnect on the router to get the latest profile increaseHuh?
Fixes: 62
Re: Should I do a soft disconnect on the router?
I don't know what you think the problem is
The current line speed matches the IP profile
TBag
@shalom2010
PN systems sync with your BT IP profile by remotely resetting your ppp session. Last week when my BT IP profile had changed, my router logs showed a ppp session disconnect/reconnect at around 5 am the next morning, and my current line speed then matched the IP profile.
NorthEasterner
Try unlocking modem. I did this and it made my upload speed rise by 2 mbits!! and download by 5mbits!!
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Fixes: 77
I'm going to say no as I can't see an issue, let us know specifically if you do have any concerns.
Adam
 Adam Walker
