Should I do a soft disconnect on the router?
- Should I do a soft disconnect on the router?
29-03-2013 9:26 AM
I've noticed in on my High Speed Broadband stats it says:
Estimated line speed:
62Mb (Accurate to within +/- 1Mbit) - Checked on 2013-03-24 09:11:39
Current line speed:
59.8 Mb
I've not had any change in IP address for around two weeks (although on dynamic) + my BT IP Profile is currently 59.8. Should I try a disconnect on the router to get the latest profile increase????
Current line speed:
59.8 Mb
Message 1 of 5
(1,066 Views)
4 REPLIES 4
Re: Should I do a soft disconnect on the router?
29-03-2013 9:28 AM
I don't know what you think the problem is
The current line speed matches the IP profile
Message 2 of 5
(406 Views)
29-03-2013 9:41 AM
@shalom2010
PN systems sync with your BT IP profile by remotely resetting your ppp session. Last week when my BT IP profile had changed, my router logs showed a ppp session disconnect/reconnect at around 5 am the next morning, and my current line speed then matched the IP profile.
Message 3 of 5
(406 Views)
30-03-2013 2:54 PM
Try unlocking modem. I did this and it made my upload speed rise by 2 mbits!! and download by 5mbits!!
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 4 of 5
(406 Views)
02-04-2013 11:52 AM
Message 5 of 5
(406 Views)
