Should I be on ADSL2+ ?
- Should I be on ADSL2+ ?
Re: Should I be on ADSL2+ ?
21-12-2010 6:43 PM
22-12-2010 10:50 AM
ADSL Link Downstream Upstream
Connection Speed 5568 kbps 448 kbps
Line Attenuation 24.0 db 14.0 db
Noise Margin 25.6 db 17.0 db
I presume by the change in connection speed that it's going to do the same 'training' of the adsl2 line as the previous one did, so whilst current speed is down by about 2mbps, it should eventually raise. Am I correct in this assumption? Thanks again
22-12-2010 10:58 AM
With a sync rate of 5568 that should bring the profile to 4500.
Jojo
22-12-2010 11:16 AM
There might be some training going on, but your line could also have been banded - which places restrictions on the speeds, and therefore tends to increase the noise margin higher than we see with the "standard" DLM on ADSL lines.
If you don't see increases soon, you might want Jojo to double-check this.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
22-12-2010 11:17 AM
22-12-2010 11:29 AM
What sort of Xmas break are you all getting, Jo? I can only imagine the hell you'll get when you have to return & pick up where you left off!
22-12-2010 11:32 AM
Today 11:31 4801 kbps (600kB/s) 381 kbps (47.6kB/s) Share
Yesterday 23:46 5594 kbps (699kB/s) 346 kbps (43.3kB/s) Share
Yesterday 19:04 6516 kbps (815kB/s) 382 kbps (47.8kB/s) Share
Dec 13, 08:47 6511 kbps (814kB/s) 380 kbps (47.5kB/s) Share
Dec 12, 20:07 6632 kbps (829kB/s) 375 kbps (46.9kB/s) Share
Dec 12, 12:00 6505 kbps (813kB/s) 249 kbps (31.1kB/s) Share
Dec 4, 22:13 6506 kbps (813kB/s) 242 kbps (30.3kB/s) Share
Dec 3, 21:06 5795 kbps (724kB/s) 378 kbps (47.3kB/s) Share
Nov 29, 10:36 6547 kbps (818kB/s) 271 kbps (33.9kB/s) Share
Nov 25, 10:22 1942 kbps (243kB/s) 378 kbps (47.3kB/s) Share
or am I
22-12-2010 11:34 AM
22-12-2010 11:35 AM
22-12-2010 12:48 PM
Quote Todays stats
I'm sorry but there's something badly wrong here. The line used to synch at 8128k on ADSL1, with that attenuation it should be much higher on ADSL2+. It's only just been swicthed to ADSL2+ so there's no way it should be banded at this point in time.
It HAS been switched hasn't it Jojo ? since there's now way to tell from those stats.
That noise margin is way too high, have you tried a disconnect/reconnect to see if the stats change ( please post the stats immediately after the reconnect ).
22-12-2010 1:11 PM
Hmm, a curious situation....
I've just been digging through the order and it appears that the order has not been able to be processed due to insufficient capacity. I've just ran a line check and see 8128k sync and 7150k profile, so I'm not sure why you should be seeing that connection rate on your router stats.
Jojo
22-12-2010 1:39 PM
22-12-2010 1:40 PM
Quote from: MisterW
Quote Todays stats
I've not long (accidentally) hit the wrong switch on the wall & switched the router off. My current stats from it are these
Connection Speed 8128 kbps 448 kbps
Line Attenuation 23.0 db 14.0 db
Noise Margin 16.1 db 25.0 db
22-12-2010 1:56 PM
Quote What is meant by insufficient capacity? That we're unable to be on adsl2+? If this is the case, I'm really mad at BT because it was their checking system that first set that hope, and then was followed up by yourselves, obviously acting on what their stats said.
In order to go to ADSL2+ you will need to be switched to the 21CN network, I guess it means the exchange capacity on 21CN is not sufficient.
The availability checking system doesn't consider capacity, only possible speed.
Quote Connection Speed 8128 kbps 448 kbps
At least you're now back to where you were before
22-12-2010 2:03 PM
As regards the provision of 21CN is there anyway that a waiting system exists, or could somebody stumble upon space on it in the future, despite people like us waiting for capacity?
I'd like to also apologise to Jo for her hard work which seemingly isn't going to come to fruition, despite it looking like they'd taken the order etc. Surely at some point there should have been someone who could've informed her that it wasn't going to happen for us, which would've saved a lot of time for all concerned.
