Shockingly slow internet speeds.
Tuna
Hey there, I've been a plusnet customer for a few years now, and we have always experienced horrendously slow internet speeds. All of the speeds that I give are using a wired connection.
When there is no one else on the network with only 1 computer wired directly to the access point doing a speed test I get this result:
rXK3T
Although with anyone else on the network then the average speeds are under 100kb/s down on a good day.
Keep in mind that that is without anyone else using the network, and even with that we are paying for faster speeds than what we're ever receiving, this speed for performing at an efficient work pace is totally impossible. Is there anyway to fix this? I work from home a lot, so I need a moderately quick internet connection, it is unbearably slow to use even an SSH connection, the busses have faster WiFi than what my WIRED connection has!
I've considered going back to BT, I know BT is horrendously awful, but at least they have technicians that will try to fix an issue. Pretty sure BT only owns Plusnet to make BT look better nowadays...
Anyway, I am currently using the ISP provided technicolor tg582n DLS Modem.
Is there anyway that I can improve my internet speeds, or should I just go to BT? Also, I am unfortunately not covered by fibre, and probably wont be for a very long time to come, the joys of living in Scotland. Cheesy
Thanks.
~Tuna.
Fixes: 162
Re: Shockingly slow internet speeds.
Looking at your estimates you should be receiving between 2.5 and 4.5Mb/s at the router.
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
ADSL Max Up to 3.5 -- 2.5 to 4.5 Available -- --
Fixed Rate
2 -- -- Available -- --
You should definitely be getting at least a little faster than you are. I've tried to make a change to help this, can you try a single disconnect/reconnect of the router and do another speedtest?
 Chris Parr
 Plusnet Staff
Tuna
Hi Chris. Thanks for replying.
Here are some more screen shots, I'll try restarting my router via the ACP and taking another speed test, although I doubt that will do much, worth a try though. Wink
rYJoj
And here is the DSL Connection info:
rYJxZ
 Here are several speed-tests done on a few servers after the restart of the router:
London, UK:
5753555879
Manchester, UK:
5753562236
York, UK:
5753568880
Paris, FR:
5753574348
Decided to take speed tests from a few different servers, and I am getting connections from most of them in an average speed of ~0.60Mb/s down, and an average of ~0.20Mb/s up. Being slower than ~96% of the UK really sucks.
Is there any chance that my connection is being limited? I pay for the Unlimited package, so I would think that I should not incur limitations, although you'd know better than me. Would a new gateway be worth it? The TG582n is pretty rubbish, but what can you expect from a £7 gateway?
Also, I might as well ask this here, where do I go to find out how to end my contract, pretty sure it ended a few months ago, quite interested in just going to BT. Wink
vericode
I have exactly the same issue, and the same router as you mentioned - i'm now thinking maybe these routers are on their last legs...? but is that even possible, surely they either work or they don't eh...
Tuna
In my experiance these routers have always preformed poorly... You'd almost be better of sending packets through two tin cans connected by a string. O.o
Although I am not sure that it is the router itself that is causing the issue, although it is certainly not helping, since I have used a fancy pants netgear router/modem in the past with plusnet, and although that did improve wireless connectivity, the speeds where still terrible. So I personally think that it is my line to the house. I guess slow internet speeds come with farm houses, so RIP. Shame that no more staff have wanted to look at this thread though.
~Tuna
vericode
Indeed, seems the planet staff might be too busy to constantly look at forums, shame...
I now have to wait for however long, with no updates, and I'm stuck at 0.5MB instead of the usual 20MB, but I'm still paying of course for 20MB.....
Update: Just restarted and gone through setup again and seems my connection speed is back to ~20MB... might be coincidence that the engineers have fixed it!
