Severe throttling (on SSL connection to News Demon)
- Severe throttling (on SSL connection to News Demon...
- « Previous
- 1
- 2
- Next »
Re: Severe throttling (on SSL connection to News Demon)
01-08-2012 8:58 AM
Any chance you can give us a screenshot of the download speeds when they are around 10Kbs just so I can see whether the software is reporting the units correctly. 128kbps equates to roughly 10-15KBs so would make sense for the speeds you're seeing.
Message 16 of 17
(251 Views)
01-08-2012 9:21 AM
I think you might be right actually about the speeds.
It was on 5KB/s when I did that wireshark last night. That's less than it should have been isn't it? Or will it go lower than 10 if there's contention?
Also, are none of the ports I posted above better for me to set it to? It's not like I'm downloading 24.7, it's just annoying when I want to watch the next breaking bad or whatever and I know I'll have to wait till the next day before it's finished.
I'll double check tonight whether the Kbs are KBs.
Message 17 of 17
(251 Views)
- « Previous
- 1
- 2
- Next »
