Setup help with new Technicolor TG582n Router
DCCOMMS
Hi
I need to change the ip range from 192.168.1.xxx to 192.168.100.xxx and i need the router to be at  100.1 .I can't find a user manual and Support don't have any answers as it is a new product.....Any ideas please ?
Fixes: 45
Re: Setup help with new Technicolor TG582n Router
I don't have a TG582n but I've just spoken to someone who's just changed the IP address and subnet of his new TG582n.
The procedure is:-
Disable the DHCP server on the router
Change the router IP.
Reconnect to router ( you may have to set a static IP the PC since DHCP is now disabled )
Change the router DHCP pool range.
Re enable DHCP server
Restart the router
Re enable DHCP on the PC if you had to set a static one earlier
There is a manual linked from this thread http://community.plus.net/forum/index.php/topic,104352.0.html
Hope that helps
Fixes: 32
There's more information here if you need it, but those instructions should be fine: http://www.technicolor.com/en/hi/digital-home/mediaaccess/dsl/wireless/adsl/technicolor-tg582n
 Adam Walker
DCCOMMS
Hi
Thank you for you advice, it worked to perfection, all systems are now up and running.
Much appreciated
Regards
David
Fixes: 32
No problem, nice to hear of another small victory on a Monday morning Smiley
 Adam Walker
