Settings for TP-Link Router for Plusnet Fibre?
- Re: Settings for TP-Link Router for Plusnet Fibre?
11-06-2013 11:27 PM
Is there anyone who uses a TP-Link router successfully with their Plusnet Fibre connection?
If so, can you please inform me of all the required settings for a nice and stable connection?
Thanks.
12-06-2013 4:57 AM
You may have to setup security/ port forwarding etc. to your needs. I had to do some stuff for voip, wireless ( both 2.4 & 5GHZ), add USB storage etc.
12-06-2013 9:27 AM
You may need to wait 5 minutes or so for the router to sync up for the first time but reboots are rapid after that
12-06-2013 11:27 AM
13-06-2013 2:21 PM
13-06-2013 6:41 PM
Quote from: GrahamClark I have a TP-LINK TL-WDR3600 dual; band router connected to my FTTC 80/20. The only thing I did was to set the WAN connection to 'PPPoE/Russia PPPoE', set your plusnet userid & password and finally set 'connect automatically' on. All the other defaults e.g. MTU = 1480 should work ok.
Sorry for the NOOB question but can you anyone give a dummies guide for the above!
Thank you
15-06-2013 1:51 PM
I got a question however. IP Gateway for the Plusnet router was 192.168.1.64
This one is 192.168.0.1
Does that matter?
Also, connection speed has lowered from 65 to 63
15-06-2013 3:00 PM
The subnet range shouldn't make any difference to you unless you have devices which you have assigned a static IP address to.
19-06-2013 11:08 AM
@OZ - no, that shouldn't make a difference - it only relates to your internal network anyway, and will only be an issue if you've set a static IP for any of the machines on your network. As long as they're all still working there's nothing to worry about there.
20-06-2013 2:50 PM
08-01-2015 6:05 PM
