Setting up old TalkTalk router to work with PlusNet?
- Re: Setting up old TalkTalk router to work with Pl...
24-07-2015 6:56 PM
Hello,
I am about to join from TalkTalk and am keeping my router, which I read elsewhere is supposed to work on PLusnet as well.
Just to be safe though, I wanted to ask how I need to configure it to work with PlusNet when its live.
The router model is a D-LINK DSL-3780
Firmware version 1.05t (presumably TalkTalk)
Hardware version B1
Many thanks in advance for any advice you can offer
Hardware version B1
Message 1 of 6
(3,193 Views)
5 REPLIES 5
Re: Setting up old TalkTalk router to work with PlusNet?
25-07-2015 10:29 AM
I moved from talktalk to plusnet 2 months ago. I chose to pay for the postage of the new plusnet router because I wanted to make sure the line was working rather than blaming the old equipment when things did not work. I managed to set up the talktalk d-link 2640R and my own zyxel H660 routers as a back up. I remember I just change the username and password, the primary and secondary DNS setting.
Message 2 of 6
(2,127 Views)
25-07-2015 11:47 PM
Which is the primary and secondary DNS setting for PlusNet?
Message 3 of 6
(2,127 Views)
26-07-2015 1:15 AM
http://www.plus.net/support/customer_service/using/settings.shtml
this may answer your question.
Message 4 of 6
(2,127 Views)
26-07-2015 1:16 AM
in case you can't see it if you are not a plus net customer.
Broadband and Dial-up DNS
Primary 212.159.13.49
Secondary 212.159.13.50
Message 5 of 6
(2,127 Views)
27-07-2015 11:19 AM
You should be ok to leave the DNS to automatically request too.
Message 6 of 6
(2,127 Views)
