Setting up another mailbox
richardquery
How to set up a mailbox on another computer, on same router, and same username but separate identity; ie:  xxxxx@username.f9.co.uk Huh?
Fixes: 10
Re: Setting up another mailbox
Have you created a new mailbox through Manage My Mail under Email Settings on the portal? That is the first step.
You may find http://www.plus.net/support/email/newemail.shtml?supporta=addaddress helpful - I think you want the Deliver to a new mailbox with its own login and password option.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
pierre_pierre
you also want to set up message rules on each PC so that it only looks at its own messages, that is done via you mail message reader.
I currently do that using both Thunderbird and IAMP to vet  all messages before downloading, then OE one on my PC and one On SWMBO machine
pierre_pierre
Oh and welcome to the Forum
Fixes: 10
Quote from: pierre_pierre
Not if he sets up a different mailbox and has each PC just reading it's own mailbox!
pierre_pierre
thought that was what message rules are, as on Plus Net, in my case I have three different extensions to play with  @username.free-on-line.co.uk; @username.idps.cp.uk and @username.me.uk, if I use the prefix mr, they all go to the same mail box.  But if I use the prefix of peter and sue, the go to two different mail boxes via message rules on both OE and thunderbird
pierre_pierre
I must admit that I have a few folders and mail boxes, I dont have a sue folder on my OE, but I do have on thunderbird, and my default doent download sue to my machine
Fixes: 10
The OP asked about setting up xxxxx@username.f9.co.uk on another PC - please don't introduce totally un-necessary complications.
Fixes: 62
Pierre,
You are just confusing the issue.
The OP just wants to setup a separate mailbox which will be accessed from a different PC only.
There is no need to create message rules at all.
All you have is me@username.plus.com being picked up from the mailbox username+me on computer 1
and you have anotherme@username.plus.com being picked up from the mailbox username+anotherme on computer 2
