Setting up an internal static IP address
johndeakin
I have a network printer on my home network and the network is set up for DHCP. Each time the printer is started up it is assigned a new IP address and my Linux printer software cannot find it so I have to reconfigure the software interface.
I have trawled through the router interface but cannot find anywhere to change the internal network from DHCP to Static. Can anyone help?
regards,
Fixes: 144
Re: Setting up an internal static IP address
What make and model of router do you have?
You need to disable the router's DHCP server and manually assign IPs to the various devices on your network.
Customer and Forum Moderator. Windows 10 Firefox 62.0.3 (64-bit)
Fixes: 95
Hi John, if you're using one of our Thomson routers then access the router interface and navigate to Home Network. You should see a network map that shows the devices that have recently been connected to your network. The printer should be listed. If you click the hyperlink that represents the printer I think you'll find an option there to request that it's always assigned the same local IP address.
johndeakin
Bob, thanks for the suggestion. I have got as far as the device page for the printer. On the page it records: "Always use the same IP address: No", however I cannot see how to change the setting. The only options appear to be "Assign a game...", "Assign the DMZ..." and "Assign the public IP address...". None of which appear to do what I want.
The router is a Technicolor TG582n. What am I missing?
regards,
knowdice
The other option is to set the printer to a fixed address outside of the normal DHCP range.
David_W
In the router config go to Home Network, then click Devices on the left.  It'll list all the connected devices and the interface (wired or wireless).  Find and click on your printer.  In the top right you'll have a link for Configure, click that and you can then set it to always use the same IP address.
Fixes: 24
Quote from: knowdice
I'm sure that is a much simpler and straightforward option.
Fixes: 144
Agreed. All he needs to know now is what the router's dhcp range is on this router.
johndeakin
David W,
Thank you for that. Exactly what I wanted.
regards,
Fixes: 95
Quote from: johndeakin
As David's pointed out, you need to click 'Configure' towards the top-right. Not the most intuitive of interfaces I'll admit!
Edit: looks like you've sorted it  Smiley
