Setting up Thunderbird
longshanks
Hi.
I am using Thunderbird as my email client, I have two emails addresses  the primary has set up fine but I cannot get the second identity to setup. Each time i try the user name and password are not regognised by the sever.
help please
1 REPLY
Fixes: 62
Re: Setting up Thunderbird
The second identity should be setup in the form <main identity>+<second identity>
For example if your username  is "longshanks" and the secondary address is "myemail" then the email account in Thunderbird would be longshanks+myemail
